For the arm lubrication, the manual recommend to use ordinary lithium grease.
However, Garden train users, which use a lot of plastic bearing on rolling stock, do have poor experience of ordinary lubricant.
www.elmassian.com]
Hopefully, I had at hand plastic compatible garden train lubricant, that I used for the Fisher.
Any lubricant not labelled 'plastic compatible' is unsafe. Most lubricant contains solvents/additive either eating the plastic or causing cracks.
You can find here (that is costly):
www.grsuk.com]
Or less costly (That is what I used)
gonitrohobbies.com]
Same on ebay UK
www.ebay.co.uk]
Edited 1 time(s). Last edit at 07/21/2015 03:13PM by PRZ.
