Fisher SD image 210715 July 22, 2015 05:47AM |
Re: Fisher SD image 210715 July 23, 2015 05:55PM |
Re: Fisher SD image 210715 July 24, 2015 04:23AM |
Greg_be
My first feedback after some prints is that the bed calibration is good, I had always various distances with the latest, now after setting M665 and M666 based on the last script, my auto alignment is now working good
G32 Calibrated 4 factors using 4 points, deviation before 0.322 after 0.000.
Re: Fisher SD image 210715 July 24, 2015 06:19AM |
Re: Fisher SD image 210715 July 24, 2015 06:35AM |
Re: Fisher SD image 210715 July 24, 2015 06:51AM |
Greg_be
With 7 points like you propose, I got these values.
Is it looks good ?
Endstop adjustments X0.94 Y0.27 Z-1.21
Diagonal 160.00, delta radius 82.64, homed height 180.44, bed radius 75.0, X 0.0°, Y 0.0°
Bed probe heights: 0.040 -0.040 -0.555 -0.196 -0.207 -0.459 -0.149, mean -0.224, deviation from mean 0.198
Bed probe heights: 0.029 -0.040 -0.555 -0.196 -0.196 -0.447 -0.149, mean -0.222, deviation from mean 0.194
Bed probe heights: 0.040 -0.040 -0.555 -0.196 -0.184 -0.447 -0.149, mean -0.219, deviation from mean 0.197
Bed probe heights: 0.040 -0.040 -0.543 -0.196 -0.184 -0.447 -0.149, mean -0.217, deviation from mean 0.194
Bed probe heights: 0.051 -0.017 -0.555 -0.184 -0.184 -0.447 -0.149, mean -0.212, deviation from mean 0.202
Thanks
Re: Fisher SD image 210715 July 24, 2015 07:30AM |
Re: Fisher SD image 210715 July 24, 2015 07:40AM |
Diagonal 160.00, delta radius 82.57, homed height 181.34, bed radius 75.0, X -1.0°, Y 0.4°
Endstop adjustments X0.57 Y0.23 Z-0.79
Re: Fisher SD image 210715 July 24, 2015 11:10AM |
Re: Fisher SD image 210715 July 24, 2015 12:35PM |
Greg_be
Result after setting M665 and M666 from the last run
Calibrated 6 factors using 7 points, deviation before 0.590 after 0.048
Calibrated 6 factors using 7 points, deviation before 0.208 after 0.096
Calibrated 6 factors using 7 points, deviation before 0.101 after 0.100
Diagonal 160.00, delta radius 82.59, homed height 181.34, bed radius 75.0, X -1.6°, Y -0.1°
Endstop adjustments X0.53 Y0.14 Z-0.66
Bed probe heights: 0.030 0.022 0.049 -0.094 -0.094 -0.101 0.199, mean 0.001, deviation from mean 0.101
Re: Fisher SD image 210715 July 24, 2015 12:42PM |
PRZ
Hello,
David, what shall we do with the column angles reported by the 6 factors test ?
Could they be reintroduced permanently in the parameters ?
Re: Fisher SD image 210715 July 25, 2015 03:55PM |
Re: Fisher SD image 210715 July 25, 2015 05:17PM |
jmg123
Hi
Has anyone got a copy of bed7.g I could look at? as PRZ said, it has been removed from the latest Fisher image.
cheers
Re: Fisher SD image 210715 July 25, 2015 06:08PM |
Re: Fisher SD image 210715 July 26, 2015 04:25PM |
Re: Fisher SD image 210715 July 26, 2015 05:23PM |
Re: Fisher SD image 210715 July 27, 2015 07:13AM |
Re: Fisher SD image 210715 July 27, 2015 07:19AM |
Re: Fisher SD image 210715 July 27, 2015 07:22AM |
Re: Fisher SD image 210715 July 27, 2015 07:40AM |
Re: Fisher SD image 210715 July 27, 2015 07:42AM |
Re: Fisher SD image 210715 July 27, 2015 08:49AM |
bluesign2k
Also, in the default config.g you provide, the endstop offsets are set with some pretty weird values. I would have thought that most users would have more benefit with them being set to 0 as an out of the box configuration.
Re: Fisher SD image 210715 July 27, 2015 08:54AM |
Re: Fisher SD image 210715 July 31, 2015 08:07AM |
Re: Fisher SD image 210715 August 03, 2015 10:04AM |
; Probe the bed and do auto calibration G1 X-64.95 Y-37.5 F12000 G4 P300 G30 P0 X-64.95 Y-37.5 Z-99999 ; X tower G4 P300 G30 P1 X64.95 Y-37.5 Z-99999 ; Y tower G4 P300 G30 P2 X0 Y75 Z-99999 ; Z tower G4 P300 G31 Z-0.2 G30 P3 X0 Y0 Z-99999 S0 ; centre, and auto-calibrate G31 Z0.1
G30 P2 X0 Y75 Z-99999 ; Z tower G4 P300 G31 Z-0.3 G30 P3 X0 Y0 Z-99999 S0 ; centre, and auto-calibrate G31 Z-0.1
