Crappy object layer on support (raft / interface)
Posted by Greg_be
July 30, 2015 02:11PM
Hi, I made some tests with more or less raft layers, more or less interface layers, different spacing (raft and/or interface), angles, and so more
Each time, the first real object layer (laid on raft / interface) is very crappy !
I think that's because this layer is printed at normal speed and not first layer speed, but I don't know how to test / correct it without editing directly G-Code
Here are some samples
Did you experienced this problem ? Have you an idea to solve it ?
Edited 1 time(s). Last edit at 07/30/2015 02:15PM by Greg_be.
Re: Crappy object layer on support (raft / interface)
August 04, 2015 06:04PM
Put 6 raft layers and 3 interface layers in the config.Try these settings, im getting great results with that. Hope this helps. Great adhesion to the bed, but easy to remive from bead and from object, with no crappy surfaces at all. Im printing at 205° with the esun filament
August 05, 2015 02:19AM
Tanks, I'll try it !
