Lever hole size + wiring socket connection July 30, 2015 04:00PM |
Re: Lever hole size + wiring socket connection July 30, 2015 04:48PM |
Re: Lever hole size + wiring socket connection July 31, 2015 02:50PM |
Re: Lever hole size + wiring socket connection July 31, 2015 03:03PM |
Re: Lever hole size + wiring socket connection July 31, 2015 04:30PM |
Re: Lever hole size + wiring socket connection August 01, 2015 06:36PM |
Sounds like you did what I did-carefully followed the diagrams when a good look at the photographs would of been more helpful!If you have inserted the wires into the wrong side of the connector careful when you remove them so you don't damage the pins-like I did!Quote
sneaky_print
1. The extruder power connector (black, plastic, female, six pins) does not seem to fit the the connector (black, plastic, male) for the Duet board. The male connector has about another 3 - 4 mm to go before it snaps in place and using a significant amount force (I tried putting it in a vice) does not help.
