Simplify3D setup? July 31, 2015 04:03PM |
Re: Simplify3D setup? July 31, 2015 04:12PM |
Re: Simplify3D setup? July 31, 2015 04:59PM |
Re: Simplify3D setup? July 31, 2015 05:48PM |
Re: Simplify3D setup? July 31, 2015 06:07PM |
Theolodian
Thanks a ton! I'll try it out this weekend. I've also commented out the homing and added the Z0.2 offset script as I had trouble printing the robot.g due to the head being too close to the print surface. It's taking longer to get the soles of his feet of the print surface than it took to print...
Re: Simplify3D setup? August 01, 2015 05:02AM |
Re: Simplify3D setup? August 01, 2015 06:25AM |
Theolodian
OK, thanks. I had seen that thread but didn't understand what I need to do. I'll have to read it a few more times. I'm happy with the 4-point probing, but at the start of robot.g it probes the centre again so maybe that's causing problems.
Re: Simplify3D setup? August 01, 2015 10:58AM |
Re: Simplify3D setup? August 01, 2015 12:00PM |
Re: Simplify3D setup? August 01, 2015 12:04PM |
Re: Simplify3D setup? August 01, 2015 12:29PM |
Re: Simplify3D setup? August 01, 2015 01:10PM |
Re: Simplify3D setup? August 01, 2015 01:21PM |
Theolodian
If you mean the bed.g in the sys folder, it has two G31 codes; Z-0.2 followed by another with Z0.1 WTF?
Re: Simplify3D setup? August 01, 2015 01:22PM |
Re: Simplify3D setup? August 01, 2015 01:23PM |
I can never understand why there would be any reason to set the first layer height to anything other than 100%, the same goes for the extrusion multiplier. Both are nothing more than fudge factors because there's something else wrong with your setup.Quote
Theolodian
I have set the first layer settings in S3D to 175%...
Re: Simplify3D setup? August 01, 2015 01:28PM |
Re: Simplify3D setup? August 01, 2015 02:25PM |
Theolodian
Z-0.5 was definitely aggressive, but a LOT better than Z0.1 FFS! Z-0.2 is probably fine, I'll try Z-0.3 next and go from there.
Re: Simplify3D setup? August 01, 2015 02:59PM |
Re: Simplify3D setup? August 01, 2015 04:16PM |
Re: Simplify3D setup? August 01, 2015 04:54PM |
Re: Simplify3D setup? August 02, 2015 03:35AM |
Re: Simplify3D setup? August 02, 2015 06:36AM |
Re: Simplify3D setup? August 02, 2015 09:32AM |
Re: Simplify3D setup? August 02, 2015 05:56PM |
Re: Simplify3D setup? August 03, 2015 10:03AM |
; Probe the bed and do auto calibration G1 X-64.95 Y-37.5 F12000 G4 P300 G30 P0 X-64.95 Y-37.5 Z-99999 ; X tower G4 P300 G30 P1 X64.95 Y-37.5 Z-99999 ; Y tower G4 P300 G30 P2 X0 Y75 Z-99999 ; Z tower G4 P300 G31 Z-0.2 G30 P3 X0 Y0 Z-99999 S0 ; centre, and auto-calibrate G31 Z0.1
G30 P2 X0 Y75 Z-99999 ; Z tower G4 P300 G31 Z-0.3 G30 P3 X0 Y0 Z-99999 S0 ; centre, and auto-calibrate G31 Z-0.1
Re: Simplify3D setup? August 03, 2015 10:37AM |
Re: Simplify3D setup? August 03, 2015 11:32AM |
Re: Simplify3D setup? August 03, 2015 12:09PM |
Theolodian
The head doesn't stay level as you move away from the centre. I am sure this isn't modeled correctly if at all. Sounds like an arm length of 165 might be a good compromise for now.
Re: Simplify3D setup? August 03, 2015 12:19PM |
