Here is my Fisher. August 04, 2015 03:48PM |
3:51:48 AM Disconnected. 3:45:20 AM G31 0 3:40:57 AM M119 Endstops - X: not stopped, Y: not stopped, Z: not stopped 3:40:48 AM M119 Endstops - X: not stopped, Y: not stopped, Z: at max stop 3:40:38 AM M119 Endstops - X: not stopped, Y: at max stop, Z: not stopped 3:40:19 AM M119 Endstops - X: at max stop, Y: not stopped, Z: not stopped 3:38:58 AM M119 Endstops - X: not stopped, Y: not stopped, Z: not stopped 3:31:01 AM Connection established! 3:30:54 AM Disconnected. 3:13:28 AM Connection established! 3:13:28 AM Page Load complete!
Re: Here is my Fisher. August 05, 2015 04:57AM |
Two modifications and laser cutting plane of parts. August 05, 2015 04:33PM |
Re: Here is my Fisher. August 05, 2015 05:43PM |
Re: Here is my Fisher. August 06, 2015 04:17AM |
Had the same problem with the belt, a layer of rubber dust on the carriage and bed. Redesigned the idler assembly with 4 screws so the idler could be angled to keep the belt in the middle.Quote
janpenguin
I noticed the timing belt is always rubbing one side wall of the belt tensioner due to flat surface of 623 bearing.
Re: Here is my Fisher. August 06, 2015 06:38AM |
Re: Here is my Fisher. August 06, 2015 06:51AM |
o_lampe
Is that the typical way to mount the belt? Looks like upside down...
-Olaf
Re: Here is my Fisher. August 06, 2015 12:19PM |
Re: Here is my Fisher. August 07, 2015 04:15AM |
Re: Here is my Fisher. August 07, 2015 04:39AM |
Re: Here is my Fisher. August 07, 2015 07:46AM |
Comments on the building instruction August 07, 2015 05:34PM |
Push some filament through the slot in the side panel and into the extruder drive block. Using the thumbwheel, engage the filament and feed a few centimetres through. Hold the thumbwheel and try to pull the filament back out. If it slips easily, adjust the idler tension using the M4 button head screw.
First print August 08, 2015 09:53PM |
7:56:10 AM M32 Robot.g File Robot.g selected for printing 7:54:03 AM G32 Calibrated 4 factors using 4 points, deviation before 0.640 after 0.000 7:50:46 AM Connection established!
Re: Here is my Fisher. August 09, 2015 11:52PM |
Re: Here is my Fisher. August 12, 2015 10:06AM |
Re: Here is my Fisher. August 12, 2015 08:26PM |
Re: Here is my Fisher. August 13, 2015 02:32AM |
Re: Here is my Fisher. August 13, 2015 04:03PM |
Re: Here is my Fisher. August 15, 2015 03:53AM |
Re: Here is my Fisher. August 15, 2015 04:38AM |
I believe it wil be rigid enough, I have just ordered some 5mm poly and so shortly will be able to give you a definitive answer.Quote
Greg_be
johneato , did you think that polycarbonate is rigid enough to make a bed ?
Re: Here is my Fisher. August 15, 2015 08:01AM |
Re: Here is my Fisher. August 15, 2015 09:34AM |
Re: Here is my Fisher. August 15, 2015 09:55AM |
Re: Here is my Fisher. August 17, 2015 03:34PM |
Having now made the bed from 5mm Polycarbonate I can say its definately rigid enough. Certainly a match for the acylic.Quote
Greg_be
Re: Here is my Fisher. August 17, 2015 05:13PM |
Re: Here is my Fisher. August 27, 2015 08:05PM |
Re: Here is my Fisher. August 28, 2015 11:33AM |
janpenguin
OpenSCAD's DXF export removes basic geometry data that CAD program requires.
I had to run a CAD program to modify the original DXF files for aluminum and steel parts.
Base plate, Steel, 5 mm (thickness)
Top plate, Steel, 5 mm, it has big triangular access hole in the middle.
Front panels, Steel, 3 mm, one panel has ventilation and mount holes for 40x40x10 fan
Side panel, Steel, 3 mm
Rods x12, Aluminium, 4 mm
(The sheet metal company didn't have 3 mm aluminium plate. 2 mm plate felt too thin, so I chose 4 mm one.)
Effector plates, Aluminium, 4 mm
Print bed, Aluminium, 5 mm
I reduced all bolt spaces to 1.0 mm and submitted final DXF files to the company yesterday after hearing advice from a technician.
Below images are the areas I have concern about laser cut result.
Re: Here is my Fisher. August 31, 2015 10:30AM |
Re: Here is my Fisher. September 16, 2015 09:00PM |
Re: Here is my Fisher. September 16, 2015 10:27PM |
