Re: Here is my Fisher. March 06, 2016 05:55PM |
Re: Here is my Fisher. March 07, 2016 07:37PM |
Re: Here is my Fisher. March 10, 2016 10:10AM |
janpenguin
Things to do:
- Relocate the extruder to outside of panel
- Replace diagonal arms with rod end bearings and carbon or aluminum rods.
- Soldering the end stop switches?
Re: Here is my Fisher. September 26, 2016 12:52PM |
; Configuration file for emaker Fisher - delta 3D printer ; 2016/09/26 01:08 ; Communication and general M111 S0 ; Debug off M550 Preprapfisher ; Machine name (can be anything you like) M551 Preprap ; Machine password (used for FTP) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0x01 ; MAC Address (must be unique on your network) M552 P0.0.0.0 ; use DHCP ;M554 P192.168.1.1 ; Gateway M553 P255.255.255.0 ; Netmask M555 P2 ; Set output to look like Marlin G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Axis and motor configuration ; Homing crashed into the bed! M569 P0 S0 ; Drive 0 goes forwards M569 P1 S0 ; Drive 1 goes forwards M569 P2 S0 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M569 P4 S1 ; Drive 4 goes forwards M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high) ; 2016/09/25 M665 L160.00 R81.08 B75.00 H177.58 M666 X0.41 Y-2.38 Z1.97 ; G32 calibration deviation 0.014 2016/09/22 18:16 ; set delta radius, diagonal rod length, printable radius and homed height ; // M665 R80.13 L160.0 B75.00 H177.11 ; // M666 X0.14 Y-1.28 Z1.14 M92 X87.489 Y87.489 Z87.489 ; Set axis steps/mm M906 X800 Y800 Z800 E1000 ; Set motor currents (mA) M201 X4000 Y4000 Z4000 E4000 ; Accelerations (mm/s^2) M203 X15000 Y15000 Z15000 E9000 ; Maximum speeds (mm/min) M210 Z50 ; Homing feedrate M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute ; Thermistors ;M305 P0 R4700 T100000 ; Uncomment for heatbed M305 P1 R4700 ; Tool definitions M140 H-1 ; Disable heatbed M563 P0 D0 H1 ; Define tool 0 G10 P0 S210 R-273 ; Set tool 0 operating and standby temperatures M301 H1 P12 I0.4 D80 W180 B300 ; Set tool 0 PID parameters ; //M92 E310 ; Set extruder steps per mm ; direct drive M92 E135.938 ;// Z probe and compensation definition M558 P4 X0 Y0 Z0 H4 ; Set Z probe type and dive height ; G31 X0 Y0 Z-0.3 P200 ; Set the zprobe height and threshold (put your own values here) G31 X0 Y0 Z-0.1 P1000 ; Set the zprobe height and threshold (put your own values here) ;*** If you are using axis compensation, put the figures in the following command ; // M556 S78 X0 Y0 Z0 ; Axis compensation here
; emake Fisher ; 2016/09/25 01:20 ; Auto calibration routine for delta printers ; Before running this, you should have set up your zprobe X, Y and Z offsets to suit your build. ; This does a single iteration of auto calibration. Run this file multiple times until the values con verge. ; Then transfer the values to your config.g file. M561 ; clear any bed transform, otherwise homing may be at the wrong height ;G31 X0 Y0 ; don't want any probe offset for this ;G28 ; home the printer ;*** Remove the following line if your Z probe does not need to be deployed ;M98 Pdeployprobe.g ; deploy the mechanical Z probe M201 X500 Y500 Z500 ; The first time the probe is used after deployment, it gives slightly different results. ; So do an extra dummy probe here. The value stored gets overwritten later. ; G30 P0 X0 Y0 Z-99999 ; Probe the bed and do auto calibration ; R (bed radius) = 75.00 (default value was 79.00) ; x = R * cos(theta) ; y = R * sin(theta) ; Alpha (X) tower = 210 (theta) ; Beta (Y) tower = 330 ; Gamma (Z) tower = 90 ; // G1 X-67.95 Y-40.5 F12000 ; Move to X tower's position 4mm off the bed ; G1 X0.00 Y75.00 Z4 F2000 G1 X0.00 Y75.00 F2000 ; 9/22 20:36 ; bed.g file for RepRapFirmware, generated by Escher3D calculator ; 7 points, 6 factors, probing radius: 75, probe offset (0, 0) G30 P0 X0.00 Y75.00 Z-99999 ; Z tower G30 P1 X64.95 Y-37.50 Z-99999 ; Y tower G30 P2 X-64.95 Y-37.50 Z-99999 ; X tower ; G30 P3 X0.00 Y37.50 Z-99999 ; half way of Z tower ; G30 P4 X32.48 Y-18.75 Z-99999 ; half way of Y tower ; G30 P5 X-32.48 Y-18.75 Z-99999 ; half way of X tower G30 P3 X0 Y0 Z-99999 H-0.2 S0 ; center, and auto calibration G1 X0 Y0 F2000 ;*** Remove the following line if your Z probe does not need to be retracted ;M98 Pretractprobe.g ; deploy the mechanical Z probe M201 X4000 Y4000 Z4000 ;G91 ;G1 S1 X170 Y170 Z170 F15000 ; go part way up to speed up homing, endstops activated just in case ;G90 ;G28 ; Home the printer again so as to activate the new endstop adjustments
Re: Here is my Fisher. September 28, 2016 12:54AM |
Re: Here is my Fisher. September 29, 2016 11:05AM |
Re: Here is my Fisher. September 29, 2016 10:12PM |
Re: Here is my Fisher. October 08, 2016 12:25AM |
Re: Here is my Fisher. October 10, 2016 03:58AM |
Re: Here is my Fisher. October 10, 2016 05:19PM |
Re: Here is my Fisher. October 19, 2016 09:05AM |
M201 X4000 Y4000 Z4000 E3000 ; Accelerations (mm/s^2) M203 X15000 Y15000 Z15000 E15000 ; Maximum speeds (mm/min) M906 X800 Y800 Z800 E800 ; Set motor currents (mA) M92 411.230
