15mm Calibration Cube - not quite "cube-uler" August 07, 2015 04:53AM |
M556 S78 X0 Y0 Z0
Re: 15mm Calibration Cube - not quite "cube-uler" August 07, 2015 05:11AM |
Re: 15mm Calibration Cube - not quite "cube-uler" August 07, 2015 08:27AM |
dc42
What layer height are you using? The Z height will be rounded by the slicer to a multiple of your layer height. You can look at the Layers preview in slic3r 1.2.9 to see whether it really is trying to print exactly 50mm high.
The extra 0.92mm size in the Y direction looks odd to me. One possible explanation is that the probe trigger height varies with position on the bed, and you haven't fully captured this in the G31 corrections in your bed.g. file. So the firmware is moving the tower positions to compensate for a geometry error that isn't there. What happens if you use just 4-factor calibration, with the tower offset corrections set to zero?
Re: 15mm Calibration Cube - not quite "cube-uler" August 07, 2015 04:16PM |
Re: 15mm Calibration Cube - not quite "cube-uler" August 07, 2015 05:24PM |
Endstop adjustments X0.99 Y1.68 Z-2.67 Diagonal 160.00, delta radius 84.20, homed height 181.35, bed radius 75.0, X 6.48°, Y 1.35° Endstop adjustments X0.92 Y1.70 Z-2.62 Diagonal 160.00, delta radius 84.05, homed height 181.29, bed radius 75.0, X 6.21°, Y 1.05° Endstop adjustments X0.92 Y1.64 Z-2.56 Diagonal 160.00, delta radius 83.98, homed height 181.28, bed radius 75.0, X 5.96°, Y 1.21° Endstop adjustments X0.91 Y1.67 Z-2.58 Diagonal 160.00, delta radius 84.03, homed height 181.29, bed radius 75.0, X 6.37°, Y 0.89°
Endstop adjustments X1.01 Y1.31 Z-2.32 Diagonal 160.00, delta radius 83.62, homed height 181.18, bed radius 75.0, X 0.00°, Y 0.00°
Re: 15mm Calibration Cube - not quite "cube-uler" August 07, 2015 07:04PM |
Re: 15mm Calibration Cube - not quite "cube-uler" August 08, 2015 04:20AM |
Re: 15mm Calibration Cube - not quite "cube-uler" August 08, 2015 05:24AM |
Re: 15mm Calibration Cube - not quite "cube-uler" August 08, 2015 06:06AM |
Re: 15mm Calibration Cube - not quite "cube-uler" August 08, 2015 06:08AM |
Re: 15mm Calibration Cube - not quite "cube-uler" August 08, 2015 06:22AM |
Re: 15mm Calibration Cube - not quite "cube-uler" August 08, 2015 06:59AM |
Re: 15mm Calibration Cube - not quite "cube-uler" August 11, 2015 02:19AM |
Diagonal 160.00, delta radius 82.13, homed height 181.93, bed radius 75.0, X 0.61°, Y 0.51° Endstop adjustments X-1.52 Y0.85 Z0.66
Re: 15mm Calibration Cube - not quite "cube-uler" August 11, 2015 03:29AM |
