Carbon Arms September 04, 2015 02:34AM |
Re: Carbon Arms September 04, 2015 03:49AM |
Re: Carbon Arms September 04, 2015 03:57AM |
Re: Carbon Arms September 04, 2015 04:23AM |
Re: Carbon Arms September 04, 2015 04:43PM |
Re: Carbon Arms September 05, 2015 03:51PM |
did you glue yours or did you just jam it in there? Not quite sure if it's tight enough to hold still... Just tested with some glued shrinktube, hope it holds up, don't want to superglue/locktite them, so much harder to get the exact length that way!
Re: Carbon Arms September 05, 2015 06:42PM |
Re: Carbon Arms September 06, 2015 06:18AM |
Re: Carbon Arms September 16, 2015 06:17PM |
Re: Carbon Arms September 16, 2015 07:49PM |
Re: Carbon Arms September 17, 2015 06:10AM |
bgkdavis
before the Armageddon I was down to 0.042
[forums.reprap.org]
This was just the first calibration after the repair, now I've got the printer back working Ill try and get the calibration better.
There is absolutely no backlash or slop in the ball-arm contacts and the whole kinematic assembly is a lot more rigid than before
The only problem I see with these arms is getting them to size is tricky and requires time and patience, but the end result looks great.
Re: Carbon Arms September 17, 2015 07:16AM |
Re: Carbon Arms September 17, 2015 02:46PM |
Re: Carbon Arms September 17, 2015 05:35PM |
Re: Carbon Arms September 18, 2015 07:08PM |
bgkdavis
That is just a direct copy of the originals all that has been done is the bottom and middle plates are merged together, it doesnt solve the problems I have with the original design and gets rid of the mdf plate which I actually want to keep.
This version merges the top and middle plates and redesigns the ball mounts, this way I keep the mdf plate and solve the adjustability problem with the balls, and hopefully improve the alignment issues that the original design and the printed copy have.
Re: Carbon Arms September 18, 2015 07:44PM |
Re: Carbon Arms September 21, 2015 02:51AM |
Re: Carbon Arms September 21, 2015 03:37AM |
Re: Carbon Arms September 21, 2015 10:56AM |
bgkdavis
Ive been thinking about dc42s sensor board, but I think it will require a signifigant redesign of both the board and effector to work, I was wondering if it was practical to remove the ir comonents from the board and mount them directly on the effector for example.
Re: Carbon Arms September 21, 2015 11:01AM |
ph610
I am interested in the effector redesign and think I will given time swap over to a modified effector plate and maybe the arms as you all have described. Wondering whether zaccom has used the DC42 IR sensor yet on the effector and if it is working Ok on his effector plate modification? I am interested since I have a board already.
Re: Carbon Arms September 21, 2015 11:04AM |
zaccom
bgkdavis
Yeah I got the board from him but need a slot in the effector to make it fit still work in progress if you find a good spot give me heads up I been trying the front, side, in the effector, pitch angel but depends on print bed I guess. I use zebra print bed with alu headbed setup.
Re: Carbon Arms September 22, 2015 04:01AM |
zaccom
ph610
Work in progress [forums.reprap.org]
Re: Carbon Arms September 22, 2015 04:50AM |
Re: Carbon Arms September 22, 2015 05:09AM |
Re: Carbon Arms September 22, 2015 05:17AM |
Re: Carbon Arms September 22, 2015 05:26AM |
Re: Carbon Arms September 22, 2015 05:29AM |
Re: Carbon Arms September 22, 2015 05:42AM |
Re: Carbon Arms September 22, 2015 05:47AM |
Re: Carbon Arms September 22, 2015 06:09AM |
