nozzel pushing down the bed! October 08, 2015 06:00AM |
Re: nozzel pushing down the bed! October 08, 2015 06:40AM |
Re: nozzel pushing down the bed! October 08, 2015 07:57AM |
This thing came out of nowhere! Mayby a video of this would help too..?Quote
bgkdavis
Is it possible you have a wiring error? the nozzle should only just touch the bed for it to trigger.
look at the z probe figure on the web interface, it should read zero then when you press lightly by each of the balls should jump to 1000.
After calibration try a paper test on a few positions on the plate, you should jog the effector down until it just traps the paper, and note the Z position, it should be the same.
If the problem gets worst as you get higher, maybe check the steps per mm factor.
Maybe try reducing your extrusion factor
Re: nozzel pushing down the bed! October 08, 2015 11:51AM |
Re: nozzel pushing down the bed! October 08, 2015 12:17PM |
Re: nozzel pushing down the bed! October 09, 2015 05:38AM |
that makes sense! theres one microswitch thats pretty messed up! i bendt it back quite a bit, it did trigger to low! gonna test it out later.. but it doesnt explain why the bed is rocking around during print..? or is this the reason for that too? figured it shouldnt be since the bed level is supposed to be calibrated before the print starts? =)Quote
dc42
If it probes the first point without slowing down, that suggests to me that the homing switch is triggering too low compared with the M666 correction you are using for that tower. After you have calibrated a few times, run M665 and M666 without parameters to see what the delta parameters and endstop corrections are, and then compare them with the values you have in the M665 and M666 commands in config.g.
