Comments in starting script cause issues October 28, 2015 02:42PM |
Re: Comments in starting script cause issues October 28, 2015 03:07PM |
Re: Comments in starting script cause issues October 29, 2015 03:59AM |
Re: Comments in starting script cause issues October 29, 2015 04:20AM |
Re: Comments in starting script cause issues October 29, 2015 04:44AM |
bluesign2k
What are you trying to do with that code? Unless I'm mistaken, the first 3 lines won't have any effect on your print... lower the head, prove the bed and do nothing with the info and then raise the head?
Theolodian
Yeah, I've been meaning to copy bed.g here instead.
Re: Comments in starting script cause issues October 29, 2015 05:37AM |
Re: Comments in starting script cause issues October 29, 2015 06:14AM |
Theolodian
Thanks, useful info!
I had originally been looking to tweak the H value depending if the print was larger or smaller because of the dip in the middle of the bed. However, I seem to have resolved that now. Large and small prints are fine with G30 H-0.3.
In terms of G31 Z both my bed.g and config.g are the standard SD card from RRP. What do I need to do with them to incorporate the G30 H-0.3 that I am currently using, so that I can just do the G32 as you suggest? Thanks a ton.
G31 X0 Y0 Z-0.1 P200 ; Set the zprobe height and threshold (put your own values here)
; Probe the bed and do auto calibration G1 X-64.95 Y-37.5 F12000 G4 P300 G30 P0 X-64.95 Y-37.5 Z-99999 ; X tower G4 P300 G30 P1 X64.95 Y-37.5 Z-99999 ; Y tower G4 P300 G30 P2 X0 Y75 Z-99999 ; Z tower G4 P300 G31 Z-0.3 G30 P3 X0 Y0 Z-99999 S0 ; centre, and auto-calibrate G31 Z-0.1
; Probe the bed and do auto calibration G1 X-64.95 Y-37.5 F12000 G4 P300 G30 P0 X-64.95 Y-37.5 Z-99999 H0.2 ; X tower G4 P300 G30 P1 X64.95 Y-37.5 Z-99999 H0.2 ; Y tower G4 P300 G30 P2 X0 Y75 Z-99999 H0.2 ; Z tower G4 P300 G30 P3 X0 Y0 Z-99999 S0 ; centre, and auto-calibrate
Re: Comments in starting script cause issues October 29, 2015 05:07PM |
Re: Comments in starting script cause issues October 30, 2015 02:45PM |
Re: Comments in starting script cause issues October 30, 2015 03:01PM |
Re: Comments in starting script cause issues October 30, 2015 03:08PM |
Re: Comments in starting script cause issues October 30, 2015 03:52PM |
dc42
G32 won't run if the towers have not been homed. Running M0 turns the motors off and the homing is deemed to have been lost. So what you probably want in your starting script is G28 followed by G32.
Re: Comments in starting script cause issues October 31, 2015 04:42AM |
Re: Comments in starting script cause issues November 07, 2015 05:27AM |
