I have reduce the retraction speed no success. I reduce to half the retraction length and it solve the problem until i started print a part with a lot of support material, so again the problem appear.
I decrease the extrusion multiplier from 0.95 to 0.90 and the problem was solved.
So the problem was that the filament was out of specs with bigger diameter >1.73mm.
