Fisher Enclosure!!! January 02, 2016 02:38PM |
Re: Fisher Enclosure!!! January 02, 2016 08:07PM |
Re: Fisher Enclosure!!! January 03, 2016 02:26AM |
Re: Fisher Enclosure!!! January 03, 2016 02:35AM |
Re: Fisher Enclosure!!! January 03, 2016 03:35AM |
Re: Fisher Enclosure!!! January 03, 2016 03:54AM |
DADIY
I found the carbon fibre rods reduced the noise levels but after 6 kgs of filament the cooling fan is getting louder, it's on my list to convert that to 12v so cheap fans can be used.
I was really suggesting you did a temporary enclosure just to prove it will fix your warping issue as that may be down to something else like bad bed adhesion or needing a raft.
Re: Fisher Enclosure!!! January 03, 2016 05:03AM |
Re: Fisher Enclosure!!! January 03, 2016 05:32AM |
DADIY
The carbon fibre rods made a big difference to me. To make them I used two 5.5mm drill bit spaced at 160mm slotted into a scrap of wood and then as I glued up each set I could slide them over the drill bits to get them all perfectly spaced, I could have used some dowel or rod but didn't have anything the right size.
The mugen track rod ends that are popular only come in packs of 10 which is a shame, but you might have different luck in Canada.
Re: Fisher Enclosure!!! January 03, 2016 11:48AM |
Re: Fisher Enclosure!!! January 03, 2016 12:07PM |
