Fisher printing of 3DBenchy January 09, 2016 04:33PM |
Re: Fisher printing of 3DBenchy January 09, 2016 04:38PM |
Re: Fisher printing of 3DBenchy January 09, 2016 05:01PM |
Re: Fisher printing of 3DBenchy January 09, 2016 08:36PM |
Re: Fisher printing of 3DBenchy January 10, 2016 05:49AM |
Re: Fisher printing of 3DBenchy January 10, 2016 07:25AM |
Re: Fisher printing of 3DBenchy January 10, 2016 08:25AM |
DADIY
You could try reducing the temperature and reducing speed. Some people also recommend printing to st a time to give the other one more time to cool down.
The official slic3r profile for fisher is on git hub here [github.com]
Re: Fisher printing of 3DBenchy January 10, 2016 12:28PM |
Re: Fisher printing of 3DBenchy January 10, 2016 04:04PM |
Re: Fisher printing of 3DBenchy January 10, 2016 04:37PM |
Re: Fisher printing of 3DBenchy January 16, 2016 10:21AM |
Re: Fisher printing of 3DBenchy January 16, 2016 11:37AM |
tblitzy
The top/bottom layers seem to have some gaps between filament prints
It appears that at the top of the arches/windows have some bulges on them
The chimney seems to bulge out slighty
Re: Fisher printing of 3DBenchy January 16, 2016 04:15PM |
Re: Fisher printing of 3DBenchy January 16, 2016 05:49PM |
Re: Fisher printing of 3DBenchy January 20, 2016 03:32PM |
rogerdiver
I don't if you have been following the Bowden tube thread? Your symptoms sound just like mine. In my case the tube being properly seated in the radiator. Once figured out every now works. Below is my last remarks copied from that thread. Perhaps might help? Paul
rogerdiver [ PM ]
Re: Issues with bowden feed...
September 11, 2015 05:43AM Registered: 4 weeks ago
Thank for this valuable thread and advice!
I remade the Bowden tube after getting a PCB drill. What a difference! Sharp and clean finish. I also pre-threaded the tube using a M4 nut before attempting to screw into radiator. Also carefully measured the length of thread and marked the guide filament so I knew when it was fully seated. 1/2 turn back suggested too. Shortened Bowden tube to have better 'fold' profile as effector moves up. Added cable tie to keep it upright at effector top.
And now a smooth insertion of filament. What a difference.
Now printing predictably. But only after resetting Slicer to default settings (too much filament in wrong places) !
Lesson for me - if having to keep adjusting retract feed and speed and temp I ought to understand the underlying issues.
Thank you all!
Edited 1 time(s). Last edit at 09/11/2015 10:40AM by rogerdiver.
Reply Quote Report
Edited 1 time(s). Last edit at 09/18/2015 08:51AM by rogerdiver.
Have a look at the topic Skipping Extruder on page 3 by kelief - many of us had similar problems that were cured when we remade the Bowden tube connection to the hot end
It seems that if the tube is not a smooth connection with no gaps the filament cools and causes the skipping on retract.
Also thread on Bowden tube
Re: Fisher printing of 3DBenchy January 20, 2016 05:52PM |
Re: Fisher printing of 3DBenchy January 23, 2016 06:38AM |
Re: Fisher printing of 3DBenchy January 24, 2016 05:48PM |
iQuote
tblitzy
I've got the printer head in pieces now, and when I manual feed the filament through the radiator/nozzle, it doesn't feed smooth.
The point that the bowden tube touches the nozzle (inside the radiator) is a point of resistance.....is this the issue?
Re: Fisher printing of 3DBenchy February 01, 2016 10:40AM |
Erik did you post this "cooling ring" somewhere? I would really like to add something like that to my ormerod... (might have missed it on your first posting).
Re: Fisher printing of 3DBenchy February 01, 2016 10:48AM |
