RepRapPro closed down, but need a rod
January 20, 2016 11:55AM
Hi!
With RepRapPro now closed, is there anywhere else that sells the Fisher rods? One of mine broke. sad smiley
Thanks!
Ronnie
Re: RepRapPro closed down, but need a rod
January 20, 2016 05:36PM
There are a few printable versions on thingiverse.
January 21, 2016 06:26AM
ronnietucker
Hi!
Thanks!
Ronnie
Hi Ronnie,
You might like to search the forum here for cabon fiber rods, there appears to be at least a batch of rods that are breaking for people. The carbon rods are quite easy to make and should even make the machine quieter to run.
January 21, 2016 10:14AM
If you PM me for my address and send me an S.A.E I'll send you an original unused Fisher rod from my reprap beta, I have some spare.
January 21, 2016 02:18PM
DADIY
ronnietucker
Hi!
Thanks!
Ronnie
Hi Ronnie,
If you really get yourself into a bind, I have a laser cutter at work that I could make you some, but may take a week to order acrylic. Your better off getting carbon fibre rods anyway, a rod to cut and the ends will run you £12.
January 21, 2016 07:04PM
The acrylic arms will always end in disappointment.... yeah, I've heard the official line that RRP had very few reports of broken arms, and yeah I appreciate that they are cheap, but, ultimately they are going to break, Carbon Arms is definitely the way to go
[forums.reprap.org]
RepRapPro Mendel 3 Tricolour
RepRapPro Fisher
-Carbon Arms
-Easy adjust Carriage+effector
-axis stiffness mods
HE3D -600 delta
-Duet 0.8.5
-PanelDue
-DC42 Height probe
-RobotDigg metal components
Simplyfy3D
RS Design Spark CAD
January 22, 2016 08:50AM
Yeah just to add a +1 to the Carbon Arms role call. I ordered the rod and used Traxxus Ends - they work like a dream.
January 22, 2016 03:20PM
Definitely make some carbon arms Ronnie...
Carbon arms description of my make
January 23, 2016 03:53PM
Build some carbon fiber rods you be happy. I have not broken one rod since I made them. The first mod I made during my build. Also, if you have access to lowes or hobby lobby, home depot you can buy a sheet of acrylic and use one of your not broken rod and trace it and then just drill your holes and cut it out with a copling saw.
Edited 1 time(s). Last edit at 01/23/2016 03:55PM by zaccom.
January 25, 2016 05:05AM
If you still have it there's also enough plastic around the original rods to make a few replacements by hand, I did this initially but they also broke or cracked.
DC42 Kossel 330mm x 2meters
My Thingiverse Creations
January 29, 2016 07:35AM
Hello ronnietucker,
We have a few original style rods in stock, see here, as well as other items you may find useful.
[emaker.io]
[emaker.limited]
