Effector for E3D v6 January 31, 2016 08:19AM |
Re: Effector for E3D v6 January 31, 2016 09:32AM |
Re: Effector for E3D v6 January 31, 2016 10:39AM |
Re: Effector for E3D v6 January 31, 2016 10:45AM |
jmg123
Good point, hadn't thought about how much the effector would tilt. In that case I'll go for the diamond, as the only real benefit to the other was that the chimera/cyclops are hot swappable with the same heatsink. Price wise they are pretty similar £108 for the cyclops, and £103 for the diamond with e3dv6 lite heatsinks or £149 with e3dv6 heatsinks
Re: Effector for E3D v6 January 31, 2016 05:44PM |
M665 R75.0 L160.0 B75 H160.0 ; set delta radius, diagonal rod length, printable radius and homed height
Re: Effector for E3D v6 February 01, 2016 03:06AM |
jmg123
With the sad demise of RepRapPro, and the uncertainty of the long term future sources of Fisher nozzles, I decided to design a new effector fan assembly that would work with E3D v6 (not lite) in Onshape . The files are public so anyone can copy or remix them.
The E3D v6 has a longer, and wider heatsink than the original Fisher one, so none of the original effector parts can really be used (including the mdf). I therefore decided to go for a fully 3D printed effector and fan covering, The size of the heatsink also meant there wasn't really a way to include the original fan from the fisher, so instead I am using a 30mm 24v one.
The heatsink is held in place by three bolts with 6 washers, one each for top and bottom. they grip fine, but I reckon there is scope for moving them inwards by ~0.3mm .
My current prototype is printed in PETG with a glass transition of 70C, I've got a thermal imaging camera on order, to see if the heatsink around the area of the fan duct can get higher than this, hopefully it should be ok, otherwise it'll have to be printed in ABS.
I reckon that there is a chance than a couple of mm of build area horizontally and around 18mm vertically, will be lost, as the fan sticks out slightly more than the effector plate, currently my Fisher is halfway through an upgrade from Acrylic/PLA Fisher beta, to a Fisher 1.0 with Polycarbonate/ABS and support for triple extruders.
The pictures are of my prototype, with a cheap e3d v6 clone, as I didn't want to damage my real one whilst designing/measuring/prototyping.
Once this is working on my fisher I will start work on a multi extruder, can't currently decide between the e3d chimera , cyclops, or a diamond hot end. The diamond's three extruders seems like overkill, but would be easy to mount, and would possibly lose less space, Designing for the other two would be quicker, but more space would be lost. Maybe I'll just machine myself some fisher XT panels, and do both
[attachment 71325 Untitled.jpg]
[attachment 71322 IMG_0470.JPG][attachment 71323 IMG_0472.JPG][attachment 71324 IMG_0469.JPG]
Re: Effector for E3D v6 February 01, 2016 04:17AM |
Re: Effector for E3D v6 April 17, 2016 05:04PM |
Re: Effector for E3D v6 April 18, 2016 04:42AM |
Re: Effector for E3D v6 April 19, 2016 01:59PM |
Re: Effector for E3D v6 June 13, 2016 09:49AM |
Re: Effector for E3D v6 June 13, 2016 01:57PM |
Re: Effector for E3D v6 June 13, 2016 03:36PM |
Re: Effector for E3D v6 October 26, 2024 07:22AM |
