Re: Dead fan? February 10, 2016 05:59AM |
Re: Dead fan? February 10, 2016 06:53AM |
Re: Dead fan? February 10, 2016 08:11AM |
Re: Dead fan? February 10, 2016 09:44AM |
Re: Dead fan? February 10, 2016 10:13AM |
DADIY
Hi Neil,
Whilst your playing with your fan I can recommend that you take a look at the latest firmware from dc42, this supports having the fan only come on when the hot end is hot. This reduces the time the fan runs if you leave your printer unattended.
A bit more info on the fan mod -
Latest DC42 firmware is on his github here - [github.com]
You'll need to add to the config.g the command M106 P1 T45 H1 - this turns on the fan at 45c and off again when its below 45c.
Then all you need to do is connect your fan to the FAN0 connector in the corner of the duet 0.6 board.
Re: Dead fan? February 10, 2016 12:16PM |
