Print bed levelling April 03, 2016 06:02AM |
Re: Print bed levelling April 03, 2016 05:24PM |
Re: Print bed levelling April 03, 2016 08:52PM |
Re: Print bed levelling April 04, 2016 06:17AM |
Re: Print bed levelling April 06, 2016 11:44AM |
DADIY
I'd also check that your three screws on your built plate are all the same height, stick your calipers over to be sure. Also check the contact points are tight as I found they can come loose and then they drift upwards a little bit.
I'd also recommend you invest £4 in a glass bed, my local glass company cut me some circles in 2mm and 4mm float and only charged me £4 each. I then use double sides carpet tape to stick them to my acrylic plates. I then use insette hair spray rather than tape or build tak.
Re: Print bed levelling April 06, 2016 11:55AM |
dc42
1. Have you measured the probe trigger height at each probe point, and used the H parameter on the G30 commands in bed.g to correct for the variations?
PRZ
Check the offset with the 'paper sheet' method.
Re: Print bed levelling April 06, 2016 12:06PM |
Re: Print bed levelling May 18, 2016 07:09PM |
Re: Print bed levelling May 18, 2016 07:14PM |
Re: Print bed levelling May 19, 2016 01:47AM |
ByteSlinger
Which H Parameters would that be? I'm a little confused. Surely this should be a Z parameter I'm adjusting?
