Fisher makes 2 more Fishers.. April 10, 2016 10:44AM |
Re: Fisher makes 2 more Fishers.. April 10, 2016 04:26PM |
Re: Fisher makes 2 more Fishers.. April 12, 2016 03:49AM |
Re: Fisher makes 2 more Fishers.. April 12, 2016 10:22AM |
Re: Fisher makes 2 more Fishers.. April 18, 2016 06:13AM |
geeksarebeta
I love my Fisher too, how have you calibrated yours? I have printed a couple of new parts but wary of using them in case they're inaccurate, leading to other prints with inaccuracies in them.
Re: Fisher makes 2 more Fishers.. April 21, 2016 07:20AM |
Re: Fisher makes 2 more Fishers.. April 22, 2016 03:39PM |
Re: Fisher makes 2 more Fishers.. April 22, 2016 05:52PM |
Geoffro
geeksarebeta
I simply print a part, measure it and I guess I've been lucky and little has been required. I used stiffer springs under the Build Plate, the ones supplied are too squishy and I tighten my belts using a Guitar tuner, I usually go for a Bass E.. just move all carriages up and tighten them until they all register a similar note when you pluck them.
I must say, for all the improvements they made, they went totally backwards in a couple of respects.The Beta and the new Fisher model... Filament loading. For lack of a better word, it sucks more now than it ever did. That curve downward into the extruder drive is a blind feed everytime and the nylon tube they supplied needs to be cut at the most perfect angle to allow a clean feed. I actually have the tube sticking out the side now and I print from overhead rolls on the wall.
OH, they also screwed up the Effector wiring - it was so neat before - now its a tight bundle of mess :/
Re: Fisher makes 2 more Fishers.. April 23, 2016 01:11AM |
Re: Fisher makes 2 more Fishers.. April 23, 2016 01:23AM |
jmgiacalone
Hello Geoff,
It's nice to see you're getting on well with your Fisher builds.
I agree the filament feed isn't ideal. When the angles are right, it works quite well as you pointed out. I'll see if I can come up with a more robust solution.
What is your issue with the effector wiring? Could you explain the mess, perhaps with some photos?
Re: Fisher makes 2 more Fishers.. August 04, 2016 07:46AM |
