Fisher heatbed
Posted by jmgiacalone
Fisher heatbed
May 31, 2016 03:23PM
We have put together a heatbed kit for people to upgrade their Fishers, to allow printing in a broader range of materials, such as ABS, HIPS and PETG. You'll need a 120W PSU, which beta owners will already have, but otherwise the bed is a straight replacement for the standard (un-heated) one.
Files are on github for those who are interested [github.com]
More details on the blog [emaker.io]
Let me know if you have any questions.
[emaker.io]
[emaker.limited]
Re: Fisher heatbed
June 01, 2016 12:43AM
Interesting, however, one of the things I liked about the Fisher bed was the way it was easy to remove the build plate for cleaning or replacing the print surface, so a quick connect/disconnect connector would be nice.
RepRapPro Mendel 3 Tricolour
RepRapPro Fisher
-Carbon Arms
-Easy adjust Carriage+effector
-axis stiffness mods
HE3D -600 delta
-Duet 0.8.5
-PanelDue
-DC42 Height probe
-RobotDigg metal components
Simplyfy3D
RS Design Spark CAD
Re: Fisher heatbed
June 01, 2016 05:04AM
Hello bgkdavis,
I did think about putting a connector above the base plate so the bed could be easily and completely removed from the machine, but decided against it for now as disconnecting it with the machine on will trigger a heater fault.
The wires are long enough to pop the bed out and away form the machine enough to clean, see a couple of photos here.
It would be simple enough to cut the wires and fit connectors on yourself if you wished to use it in this way. Something like the Molex Microfit range should be suitable.
Edited 1 time(s). Last edit at 06/01/2016 05:04AM by jmgiacalone.
[emaker.io]
[emaker.limited]
Re: Fisher heatbed
June 01, 2016 11:53AM
Wow that looks great, I think I'll order one tonight, I have a couple of questions though:
  • Will the heatbed take 24 Volts?
  • Have you get any bed springs available for purchase?
Re: Fisher heatbed
June 01, 2016 06:38PM
Hello jmg123,
I've been planning to test the Fisher with 24v, and in fact received a suitable power supply in the post today, so I'll let you know how it goes.
We do have bed springs. I'll get them listed on the site over the next couple of days.
[emaker.io]
[emaker.limited]
Re: Fisher heatbed
June 01, 2016 08:38PM
While your stocking upgrade kits you could do a lot worst than put up a Carbon arm kit to replace the RRP crappy acrylic arms, and speaking of broken acrylic I need to replace one of the side panels on mine
RepRapPro Fisher
-Carbon Arms
HE3D -600 delta
-Duet 0.8.5
-PanelDue
-DC42 Height probe
Simplyfy3D
RS Design Spark CAD
Re: Fisher heatbed
June 02, 2016 05:15AM
jmgiacalone
Hello jmg123,
Great thanks, I've converted my fisher to 24V and be powered by one of these so I can also easily try it at 19V and 24V, just wanted to check, that the 24V was theoretically possible before I gave it a go.
Re: Fisher heatbed
June 03, 2016 05:42AM
Thanks for the bed !!! I ordered one and some spare parts by the way.
I can not wait to test it !
Re: Fisher heatbed
June 03, 2016 06:18AM
@Greg_be
Thanks for your order! I'm just waiting for the packing boxes to arrive, so I'll try and get a batch of heatbed kits out today.
@jmg123
You may need a power supply which can provide more current than the one you linked to.
Cartridge heater resistance is 6 Ohms and the bed is 3 Ohms. So at 24v, the hot end will draw 4A and the bed 8A. Your power supply therefore needs to be able to supply at least 12A at 24v, or 288W power. These figures cater for powering all the heaters at full power, which is not necessary except to speed up the warmup time from cold. During printing, the heaters operate at a fraction of their maximum power.
You can adjust the M301 S parameter to reduce the power available for the heaters, but with only 5A available, I fear you may need to reduce the power so much that your heaters will not be of much use.
[emaker.io]
[emaker.limited]
Re: Fisher heatbed
June 03, 2016 11:41AM
jmgiacalone
@jmg123
It think it should be ok, the e3dV6 30w Cartridge on my hotend is 24Volts/19.2Ohms = 1.25Amps . The PSU has a function where you can internally chain both channels together in series or parallel for 60v/5A or 30v/10A, so allowing for the overhead of the duet itself (~150mA) and the 4 steppers (500mA Each) means that it should be able to feed the bed around 6.6A = ~ 158W ~ 83% of the intended power whilst running everything flat out, or more if the motors aren't doing anything during initial bed warmup phase. I always run it with the over current and over voltage protection enabled, so if it cuts out, I can just back the bed power down a fraction until it is happy.
Edited 1 time(s). Last edit at 06/03/2016 11:41AM by jmg123.
Re: Fisher heatbed
June 06, 2016 06:40AM
Its really good to see that the Fisher kit is being actively supported again, have you got any other upgrade kits in mind? Perhaps the multi colour extruder?
DC42 Kossel 330mm x 2meters
My Thingiverse Creations
Re: Fisher heatbed
June 10, 2016 01:24PM
I've received the package this morning, thanks JM.
I'll test it this weekend
Re: Fisher heatbed
June 12, 2016 01:56PM
Just got round to installing my heated bed kit, works like a charm , Polycarbonate printing with no warping smileys with beer
Re: Fisher heatbed
June 12, 2016 03:17PM
Awesome! I have misplaced my spool of Polycarbonate, so I couldn't test that material, but I'm pleased to see it working for you.
What temperatures are you running?
[emaker.io]
[emaker.limited]
Re: Fisher heatbed
June 12, 2016 05:44PM
I printed with an extruder temp of 265 degrees and a bed temperature of 85 degrees. This was a slightly higher bed temperature than in the polymaker pc-plus data sheet, but i wanted to try and counteract some of the effect of the airflow coming from the nozzles. It stuck to the buildtak slightly too well, making it a little differcult to get the part off at the end, next time I think i'll print with a raft , as suggested in the polymaker datasheet.
Re: Fisher heatbed
June 12, 2016 06:13PM
You may find it better to print onto Kapton then. When it cools, parts tend to come off more easily.
If you don't want the airflow across the top of your part from the nozzle ducts, you can easily remove them. There'll still be a downdraft over the part, but it won't be so aggressive. That's what I do when printing with ABS, as otherwise it tends to delaminate during printing.
[emaker.io]
[emaker.limited]
Re: Fisher heatbed
June 25, 2016 04:15PM
Re easy heatbed removal on the Fisher, I have fitted a JST dual line connector pair, available from RC modelling suppliers and ebay, in-line with the heatbed black & red thermistor wires and the existing thermistor PCB connector. The polarised JST connector plug and socket are thin enough to slip through the curved wiring slot in the Fisher base and will normally sit out of sight underneath the base, if fitted near the PCB end of the existing leads.
This addition makes the heatbed completely removable and will ease replacing Kapton and carrying out other maintenance on the Fisher. This arrangement has little chance of becoming accidentally disconected as the JST plugs and sockets are quite firm once fully engaged. If you have not used JST connectors before, I suggest you purchase a crimping tool, rather than try to solder the JST plug's contacts. Works a treat!
Edited 1 time(s). Last edit at 06/25/2016 04:20PM by SSMagic.
SSMagic
Fisher Beta, upgraded to Fisher 1 with heatbed and full fan control
Re: Fisher heatbed
July 16, 2016 02:15PM
Finally, one month later (i'm not using it everyday), some news about my heated bed.
I tried with my worst filament, a red PLA from Prima3D
After some tests with Kapton tape,there was no grip at all.
I installed the BuildTak, bed at 70 and filament 200, the filament is sticking well.
I can finally finish my spool with other things than failed parts!
Here is an example : a reworked part to replace the acrylic arm from the extruder.
This kind of part with small footprint was impossible before
I enjoy it
Re: Fisher heatbed
July 18, 2016 10:39AM
With my home made heat bed I'm using 4mm glass from the local glass company with a little hair spray for PLA or ABS juice for ABS and its working great. For ABS I have a cardboard box folder into a hexagon that forms a make shift enclosure which has made a world of difference.
Re: Fisher heatbed
September 03, 2016 04:35PM
Looking for help with heat bed upgrade. I noticed that the upgrade sits a few mm higher than the cold bed, I had the miss fortune of the hot end crashing into the bed
When I tried to home.
I did copy new sys files over. I have removed it for now
Can anyone advise ..
Steve
Re: Fisher heatbed
September 04, 2016 08:11AM
Hello Steve,
The homed height in config.heatbed.g was set a little high. It has now been reduced to 161mm and updated on github. See the M665 command to adjust.
Sorry for the trouble caused.
[emaker.io]
[emaker.limited]
Re: Fisher heatbed
September 04, 2016 09:10AM
Thank you so much for fast reply, yes all fixed and working, have you a new Stl for the extruded update and the pneumatic fittings
Steve
Edited 1 time(s). Last edit at 09/04/2016 09:11AM by stevebeale.
Re: Fisher heatbed
October 17, 2016 12:21PM
Just ordered one today. Can't wait to try it. Forgot to order a new Buildtak with it though.
Re: Fisher heatbed
October 17, 2016 03:08PM
The sd card I was using became corrupted and I reformatted to remove issues. After re-loading the Firmware and other folders onto the card, amending the config g file to ensure correct height of the nozzle from the heatbed and other settings I re-inserted the sd card into the fisher. Unfortunately it no longer picks up the heatbed on the DWC Panel. I added the command M305 P2 R4700 to thermistor category under the previous M305 command for the nozzle but the heatbed is still not showing on the DWC Panel. Thanks in anticipation.
Re: Fisher heatbed
October 17, 2016 03:33PM
Gary J
Sounds like you may still have a M140 H-1 command in your config.g file. If so, remove it or comment it out.
Re: Fisher heatbed
October 17, 2016 04:12PM
Thanks dc42, after checking the command was still applied. I have removed and all seems well.Thanks again.
Re: Fisher heatbed
October 18, 2016 02:38AM
Fisher has one heat sink fan that blows air into the fan duct. It's built for PLA.
How do you guys print PLA and ABS alternatively?
Re: Fisher heatbed
October 18, 2016 04:14AM
For ABS I put a little masking tape under the fan duct and then put a cardboard enclosure around the machine to keep some heat in and avoid drafts, I'm still very much experimenting with ABS but have managed to print the gear bearing successfully. [www.thingiverse.com]
Re: Fisher heatbed
October 20, 2016 11:04AM
I bought the kit from emaker.io and am very impressed. Very easy to build and easy instructions to follow. Jean-Marc was able to respond very quickly to a quick question I had.
I've made a slight modification to mine and added an EC3 connector and RC servo connector to the wires of the heatbed. This is in case I want to fully remove the bed to remove intricate prints or clean the bed or maybe go back to non-heat bed.
I printed my first 20x20mm cube in ABS this morning and am very impressed it worked first time!
Edited 3 time(s). Last edit at 10/21/2016 06:25AM by AndyKay.
Re: Fisher heatbed
November 14, 2016 08:51AM
Hi All
Recently purchased 3mm float glass for the Fisher to place on top of the heatbed. I need to fasten the glass to stop it moving when printing but I would rather not use using glues etc. The issue which I sure you are all aware of is that there is minimal space to apply bulldog or similar clips.
Does anyone have any suggestions as to what clips I can use, I tried printing some with PLA but the are very brittle and break easily.
Your help is much appreciated.
