Printing problems [SOLVED]
Posted by Kalle
June 22, 2016 02:43AM
Hello,
my Fisher started to do prints with problems recently. I have no clue what it can cause the issue. I moved the printer a lot because I showed it to friends.
I am attaching some reference pics, hope someone can point me in the right direction.
Edited 2 time(s). Last edit at 06/29/2016 05:15PM by NewPerfection.
Re: Printing problems
June 22, 2016 06:06AM
At a guess Id say you have something loose.
check all 12 balls are tight on the screws,
check the linear bearings are tight in the carriages,
check the arms are not cracked
check the belt drive gears are tight on the motor shafts.
RepRapPro Mendel 3 Tricolour
RepRapPro Fisher
-Carbon Arms
-Easy adjust Carriage+effector
-axis stiffness mods
HE3D -600 delta
-Duet 0.8.5
-PanelDue
-DC42 Height probe
-RobotDigg metal components
Simplyfy3D
RS Design Spark CAD
June 28, 2016 06:56AM
Thanks for the input bgkdavis,
I checked all what you suggested and now is printing slightly better compared to the initial prints.
Some of the plexy rods still have parts that are ruined like this ones. Should I get new plexy rods?
I love this printer but I new to deltas.
June 28, 2016 08:37AM
Make yourself a set of carbon fibre replacement arms - you won't be disappointed. There's lots of details in this forum but here's a link to get you started.
[forums.reprap.org]
DC42 Kossel 330mm x 2meters
My Thingiverse Creations
June 28, 2016 09:17AM
c'est moi ou il y a encore le film PVC dessus ?
did you remove the protective pvc film on the rods ?
June 28, 2016 09:22AM
DADIY
[forums.reprap.org]
I will look for carbon fiber replacement, in the meantime can you confirm if I need to replace the rods when they are so ruined?
Martoh
yes I did
June 28, 2016 06:14PM
Those marks are telling your something, they are rubbing, you need to identify what they are rubbing on and fix it.
The arms are probably OK for now, but you should definitely look at making a set of carbon arms, the acrylic arms break.
RepRapPro Fisher
-Carbon Arms
HE3D -600 delta
-Duet 0.8.5
-PanelDue
-DC42 Height probe
Simplyfy3D
RS Design Spark CAD
June 29, 2016 02:54PM
bgkdavis
I will look into making carbon arms, is anyone selling them already?
In the meantime I cutted new acrilyc arms and now it prints fine. On the left with old arms on the right the new ones.
