Assembly woes.
Posted by Neil Mudford
Assembly woes.
September 20, 2016 04:03AM
One of my carriages won't move the microswitch lever sufficiently. The gap between the steel rod and the Perspex cover is a good 0.5mm wider than the other two. I'm talking to the supplier about this and will let you know the outcome.
As you can see, it travels further up than it should.
Rgds Neil.
open | download - Y-Header_S.jpg (85.1 KB)
Re: Assembly woes.
September 20, 2016 03:49PM
See the uploaded image . Move the part on the red cycle on the top side NOT the button
Re: Assembly woes.
September 22, 2016 07:05PM
I have made an effective repair to the printer by adding a small wedge to the 'Y' carriage as shown.
Regards,
Neil.
open | download - Y-Header Repair.jpg (115.3 KB)
Re: Assembly woes.
September 23, 2016 05:31AM
Ideally, you want all the carriages to be at the same height when they home. You might want to consider printing a new carriage to replace this one when you get the printer working or at least placing wedges on the carriages.
Out of interest was the carriage getting to the absolute top before the switch didn't trigger or was it getting stuck roughly where you have it in the photo. I have seen the later happen on a Fisher and the fix was to increase the motor currents and slow down the initial home in homedelta.g.
For example the default -
G1 S1 X180 Y180 Z180 F5000 ; move all carriages up 320mm, stopping at the endstops
becomes
G1 S1 X180 Y180 Z180 F4000 ; move all carriages up 320mm, stopping at the endstops
and in config.g
M906 X800 Y800 Z800 E1000 ; Set motor currents (mA)
became
M906 X900 Y900 Z900 E1000 ; Set motor currents (mA)
DC42 Kossel 330mm x 2meters
My Thingiverse Creations
Re: Assembly woes.
September 23, 2016 06:01AM
Hi Neil, I filed the slots that hold the microswitch to allow it to move to the left slightly. All works fine when selecting all home button. The modification keeps all microswitches at the same height.
Re: Assembly woes.
September 23, 2016 06:28PM
Hi Dadiy,
Roughly as per the photo. The toothed belt top surplus prevented further movement up (as visible in the first photo).
I used my callipers to measure the drop from the underside of the top brackets to the carriage top on the x-tower and used that to set the correct distance. I made the wedge slightly thicker before gluing it into position then used a small file to narrow it until the microswitch clicked at the right height.
Rgds,
Neil.
Re: Assembly woes.
September 24, 2016 04:02AM
I think I would have trimmed the belt surplus a little but you might also find more power to the motors pushed it to the side.
Just be sure to have a measure after homing to check the distance between carriages and the top are all the same.
Re: Assembly woes.
September 24, 2016 05:30PM
It is all rather academic at the moment as a wire has broken off the fan motor sad smiley
Does anybody know of a decent UK source of spare parts??? smiling smiley
Rgds,
Neil.
Re: Assembly woes.
September 26, 2016 02:51AM
Re: Assembly woes.
September 26, 2016 12:36PM
Thanks Dadiy - replacements ordered.
