My problem is similar to others on this forum.
I have finished assembly and when I connect USB lead all lights come on and end stops work.
I have downloaded from GitHub the firmware bin for 15e and flashed this successfully to the Duet Board. I also copied DWC 1.12 to www on SD Card and other directories from the SD image.
USB TESTS
My PC runs under Windows 10
With SD Card in the printer and USB cable connected I run Arduino. When I check Tools the BOARD is Arduino Duet (Native USB port), the PORT is COM9 and the PROGRAMMER is AVR ISP.
The Device Manager indicates under Ports(Com & LPT) - Duet 3D Printer control electronics (COM 9)
When under Arduino I run Tools/Serial Monitor and send the command M115 I get the following six lines
Cannot initialise SD Card 0: Card not found RepRapFirmware for Due Version 1.15e dated 2016-10-02
Executing default.g (no configuration file found) ... Error, Not found
Starting Network...
ReRapFirmware for Duet is up and running
FIRWARE_NAME: RepRapFirmware for Duet FIRMWARE_VERSION: 1.15e ELECTRONICS: Duet 0.6 DATE 2016-10-02
Ok
ETHERNET CABLE TESTS
I run Delta Fisher with only Ethernet cable connected to PC and mains power switched on.
When I go to a web and input http:/ reprapfisher it cannot find page
Please tell what is wrong ?
Regards
Leslie Ward
