Extruder idle lever tension - stops extruding November 07, 2016 06:24AM |
Re: Extruder idle lever tension - stops extruding November 07, 2016 01:32PM |
Re: Extruder idle lever tension - stops extruding November 08, 2016 06:42AM |
Re: Extruder idle lever tension - stops extruding November 09, 2016 03:34AM |
M906 X800 Y800 Z800 E800 ; Set motor currents (mA) ; 10/19 13:45 reduced extruder motor's acceleration (4000) M201 X4000 Y4000 Z4000 E3000 ; Accelerations (mm/s^2)
Re: Extruder idle lever tension - stops extruding November 09, 2016 04:28AM |
M906 X800 Y800 Z800 E1000 ; Set motor currents (mA) M201 X4000 Y4000 Z4000 E4000 ; Accelerations (mm/s^2)
Re: Extruder idle lever tension - stops extruding November 09, 2016 06:43AM |
Re: Extruder idle lever tension - stops extruding November 09, 2016 07:33AM |
Re: Extruder idle lever tension - stops extruding November 09, 2016 03:53PM |
Re: Extruder idle lever tension - stops extruding November 09, 2016 10:46PM |
M906 X800 Y800 Z800 E1080 ; Set motor currents (mA) M201 X4000 Y4000 Z4000 E1000 ; Accelerations (mm/s^2)
Re: Extruder idle lever tension - stops extruding November 10, 2016 12:19PM |
Re: Extruder idle lever tension - stops extruding November 12, 2016 05:36PM |
Re: Extruder idle lever tension - stops extruding November 13, 2016 12:42PM |
Re: Extruder idle lever tension - stops extruding November 14, 2016 05:13AM |
pixelseventy2
OK, so, the story so far...
New motor, 1703HS168A, running at 1200mA. Extrusion acceleration at 1000 mm/s2. Retraction speed in slic3r 10 mm/s, length 3.4mm. New nozzle. Tensioner looser than I've had it before though. Spent the time trying to make sure the bowden tube to nozzle join was a good as I could get it.
Managed to get to 80% on this print, which is better than before, but still 20% off where I need to be.
Things to try. Increasing the current more (the motor is rating for 1.68A, and I gather the duet 2A). Tightening the tensioner a bit more. Try a filament cleaner/lubricator like this: [www.thingiverse.com]
Re: Extruder idle lever tension - stops extruding November 14, 2016 05:28AM |
Re: Extruder idle lever tension - stops extruding April 18, 2017 08:46AM |
pixelseventy2
When it stops extruding it just grinds the filament.
Re: Extruder idle lever tension - stops extruding April 18, 2017 01:51PM |
Admin Registered: 14 years ago Posts: 2,569 |
Re: Extruder idle lever tension - stops extruding April 18, 2017 02:45PM |
