heater cartridge on its way out??
Posted by jimmyjim
March 30, 2017 11:03PM
The new belts are now in, the little Fisher is back to perfect prints!
I've noticed that I'm having to print higher temps now. I run "0" in the slicer, then manually set the temp as required, it was 210, when I started, I'm now running 245/250!
I've had a quick look, it appears to be 19v and 60W, can't find anything!
Any advice, please.
Cheers Jim
Re: heater cartridge on its way out??
March 31, 2017 02:43AM
It's more likely to be a problem with the thermistor. Check that the wires are not shorting against the heater block.
Delta printer calibration calculator, mini IR Z probe, and colour touch screen control panel: [escher3d.com]
Large delta printer, and other 3D printer blog postings: [miscsolutions.wordpress.com]
Disclosure: I have a financial interest in sales of the Panel Due, Mini IR height sensor, and Duet WiFi/Duet Ethernet [www.duet3d.com].
