Fisher won't home successfully
Posted by The_Taskman
June 10, 2019 04:18PM
I've built a fisher kit from scratch. I have updated the firmware to 1.23 from the reprap ltd GitHub site and am able to connect ok. I have been running through the commissioning page and the motors are setup and working in the correct direction and the end stops trigger successfully on testing.
However, on the next step when I click the 'Home All' button one out of the three fails to home successfully. And reports an error. I've not found anything in troubleshooting or on this forum that describes this issue so am seeking help to fix it.
Re: Fisher won't home successfully
June 10, 2019 04:35PM
Check [duet3d.dozuki.com].
June 12, 2019 09:53AM
Thank you dc42.
It turned out I had 2 of the end stops back to front as I was running through your linked article I found the issue was with the reported end stops, switched them over and re-ran the homeall after updating with the suggested values and everything is now homing successfully.
Cheers
