Can you Kiwis help an Old man Emu?
I've got a desktop CNC machine and I was considering fitting an extruder head to it so I could play with reprapping.
I have three steppers which are run off a single board. I am using MACH3 CAM software to read the G-Code and activiate the steppers.
What I'd like to see is an overview of how the electronics of reprap work. Going backwards, I understand that the stepper motors are controlled from the motherboard. The extruder has its own controller board. Where does it get its commands from?
What is the motherboard doing?
The software I use can control the steppers, and is able to generate a signal to control up the extruder motor.
Also, if the role of teh stepper in the extruder head is to feed the plastic into teh heater unit, why does it have to be a stepper motor?
Thanks for your help
Old Man Emu
