3D Printer Build (Napier - NZ) October 01, 2011 06:50AM |
Re: 3D Printer Build (Napier - NZ) October 02, 2011 06:08AM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: 3D Printer Build (Napier - NZ) October 04, 2011 02:29AM |
Re: 3D Printer Build (Napier - NZ) October 04, 2011 04:15AM |
Re: 3D Printer Build (Napier - NZ) October 04, 2011 05:52AM |
kthx
ideal motors are NEMA17 size, rated 1 to 4 volts, 1.5A, 3 to 8 mH, 62oz.in (44Ncm, 4.4kg.cm) or more of torque, 1.8 or 0.9 degrees per step (200/400 steps/rev respectively) such as the kysan 1124090/42BYGH4803 for example
Be sure to get ones with at least 20mm of shaft length. Shorter shafts require modifications to the X pulley assembly and Z motor couplers. One of the five motors, for use with the extruder, should be capable of creating a holding torque of at least 40Ncm, at the very least.
Re: 3D Printer Build (Napier - NZ) October 05, 2011 12:11AM |
Re: 3D Printer Build (Napier - NZ) October 05, 2011 05:52AM |
Re: 3D Printer Build (Napier - NZ) October 05, 2011 03:37PM |
Admin Registered: 17 years ago Posts: 179 |
Re: 3D Printer Build (Napier - NZ) November 15, 2011 02:19AM |
Re: 3D Printer Build (Napier - NZ) November 15, 2011 04:45AM |
Re: 3D Printer Build (Napier - NZ) November 15, 2011 02:56PM |
Re: 3D Printer Build (Napier - NZ) December 02, 2011 03:37AM |
Re: 3D Printer Build (Napier - NZ) December 02, 2011 04:09AM |
Re: 3D Printer Build (Napier - NZ) December 02, 2011 05:32PM |
Re: 3D Printer Build (Napier - NZ) December 03, 2011 04:27AM |
Re: 3D Printer Build (Napier - NZ) December 04, 2011 07:36PM |
Re: 3D Printer Build (Napier - NZ) December 04, 2011 08:57PM |
Re: 3D Printer Build (Napier - NZ) December 04, 2011 10:40PM |
Re: 3D Printer Build (Napier - NZ) April 22, 2012 04:49AM |
