First error hurdle
Posted by 41southrap
First error hurdle
December 13, 2012 08:38PM
Hi all,
Just tried to get the electronics working and have this error;
start
echo: External Reset
Marlin: 1.0.0 RC2
echo: Last Updated: Dec 14 2012 14:20:23 | Author: nophead
echo: Free Memory: 5603 PlannerBufferBytes: 1232
echo:Using Default settings:
Error:0
: Extruder switched off. MINTEMP triggered !
Errortongue sticking out smileyrinter stopped due to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
Resend:1
ok
Not sure what to do here. The electronics are RAMPS 1.4 and the extruder stepper is plugged in but not the thermistor or hot-end. Will that cause this error? Guess I should connect them and find out.
Re: First error hurdle
December 13, 2012 10:30PM
You need to plug in the thermosistors or disable the temp/ thermosistor setting in in marlin fimware . .someone correct me but on the top of my head change to zero "0" value . .this is good if your are testing motor functions . .or calibrating your x,y,z axis
December 13, 2012 10:31PM
I got that error a couple of times.
First time, my thermistor (the one that reads the temperature) wasn't connected properly.
The second time was because I had blown a few resistors, so I tried a suggestion of Vik's and built my own resistor out of nichrome wire wound around the heater block and imbedded in furnace cement. This time it was intermittent and I finally figured out htat the furnace cement hadn't dried 100%. After a few faulty goes, it heated up enough to dry completely and I haven't had a problem for a couple of months.
December 13, 2012 11:21PM
Alizier21 - any idea where in the code that switch is? I didn't see anything in either the configuration.h or the configuration_adv.h (could be a "man" look of course!)
Otherwise I'll wire up the head tomorrow - which needs to be done anyway.
Cheers
Colin
December 14, 2012 03:23AM
loading marlin to ramps 1.4<< not sure how to upload video so it will show here confused smiley
The link is a video loading marlin onto ramps 1.4 . .
Just change the "1" to a "0" value for the hot end and the bed . .
Hope it helps . .
December 14, 2012 03:25AM
Its in config.h BTW . .smiling smiley
December 14, 2012 03:38AM
Just check marlin . . I>>change to "0" to disable ( not used)n config.h tab, line 78 . .
Sumptin like this:
#define TEMP_SENSOR_0 1>>> change to "0"
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_BED 1>>>change to "0"
Note that you have to change this back to whatever your thermosistor value is
before using your hot end and heat bed . .
Github reference:
[github.com]
December 14, 2012 02:58PM
Excellent, thanks, that makes perfect sense now I look at it.
