hot temp run away
Posted by guyfromwellington
hot temp run away
July 06, 2012 05:34AM
Hi
I have a problem with my orusa hot end, the temperature continues to climb regardless of what temperature I set it to.
Any ideas on what the problem is?
Regards
Keith
Re: hot temp run away
July 06, 2012 06:04AM
What model of hotend, thermistor, electronics, firmware, control software are you using ?
When you say it continues to climb, is that what is reported by the reprap control software you use, or something you notice by another way of measuring temperature ?
Please detail how your hotend thermistor (or other kind of heat measurement device) is plugged (pictures would be nice).
July 06, 2012 04:40PM
Hot end: j head 0.5mm mark iv-b
Thermistor: stock
Electronics: Sanguinololu 1.3a
Firmware: arduino
Software: pronterface
I set the temp to 180 and to monitor. The temperature climbs steadily and doesn't stop at the preset set. This is confirmed by smell and hot end dripping, so there is a definite issue.
The thermistor has two wires that plug into the board in the top left corner of the board, connections and wires appear to be in good condition.
I haven't used the printer for a few weeks and never had the problem prior to yesterday. I uploaded the firmware thinking this would fix it, but nothing changed.
Help?
July 06, 2012 04:45PM
Here are the pictures
open | download - IMG_20120707_084821.jpg (163.8 KB)
open | download - IMG_20120707_084750.jpg (212.6 KB)
July 06, 2012 08:44PM
Since your able to read the temp, Im thinking the thermistor is fine.
Witch leaves the firmware, and FET and micro to check
It sounds like the firmware is fine, if it can read the temp and turn on the heater it should be able to turn it off.
If you just turn it on and leave it the hot end does stay at room temp? (ie its not always heating is it?)
If your up to some soldering swap your two FETs over and see if the issue swaps to the Hot build platform.
If it does its the FET, if it doesn't I'm suspecting the pin on the Micro (bad soldering or dead micro)
July 06, 2012 10:11PM
Thanks for the advice dust, will do the swap tonight and let you know.
When I connect the printer, and switch on monitoring the hot end just reads room temp, it only goes spastic when the hot end temp is activated.
Thanks again
