rostock delta robot
August 02, 2012 05:04AM
Im thingking of building a rostock printer . . .anyone here in nz tried or has a working printer? Advice and commnet please ?
Re: rostock delta robot
August 02, 2012 05:50AM
Im gathering parts to build one...
Its only been out a little while, I don't think there are any in NZ yet.
August 02, 2012 06:42AM
Thats cool . .have you printed all the parts? keep me posted . .
August 02, 2012 07:32AM
Have not started printing yet, Finishing off my mendelmax first.
Also sadly the rods and pulleys and belts are all back ordered, vxb tells me it could be several months for the rods
Also cant get the ptfe tube... available from mcmasters (the rotters who wont ship outside of the US) But will work on that when I have the delta moving, also wanting to try a 3mm bowden as 1.75mm is just to expensive!
August 02, 2012 04:09PM
There are companies where for a small fee you ship to them in the states and they on send, can't remember the name of one I have used before at the moment let me think on it a while
__________________________________________________________________________
Experimenting in 3D in New Zealand
August 02, 2012 04:11PM
Why not get the rod locally 8mm rod is available quite cheap from places such as tata steel, they are in Nelson and Christchurch it's where I go
August 02, 2012 04:51PM
Because I want decent, ground, hardened and chrome plated steel at an affordable price.
August 02, 2012 06:31PM
I used 216 8mm stainless steel from steels and tubes. . And they worked out alright on my prusa build . .i plan to use the same when i start on the delta robot . . .might use 10 mm though
August 03, 2012 07:07AM
teflon tube sorted (for those planning on using 3mm )
[www.ebay.com.au]
Some people may want a larger internal diameter, but so far all 3mm PLA from Diamondage has been around 2.75, so thats lot of clearance in my books.
This supplier has other diameters...
Edited 1 time(s). Last edit at 08/03/2012 07:11AM by Dust.
August 03, 2012 08:25PM
25ft for 15.80US? nice find Dust.
let me know when you've got it, I might buy a few meters from you - unless you're intending to use the whole amount :p
August 04, 2012 07:33AM
Im fairly sure I will have lots left over
Col
August 10, 2012 11:20PM
I use myus.com to source gear from the US. Not the cheapest way to do it i'm sure but havent had any problems to date.
I will be ordering 1.75mm tube from mcmasters when I have the steppers running, happy to order extra if people need it.
Can someone point me to a person/company that will print the parts for the rostock here in NZ?? Happy to pay.
Cheers
August 11, 2012 04:01AM
Hi Col
Where in Nz are you?
I could print them, but im in Chch
Col
August 11, 2012 10:25PM
Dust,
I'm in beautiful Queenstown, don't mind picking up the tab for freight.
Cheers
August 12, 2012 01:03AM
Col, Ive sent you a PM about plastics
August 15, 2012 05:28AM
My teflon tube arrived today, It looks good. Seem to be a good size and filament moves nicely in it.
August 15, 2012 06:59PM
Just in time too. im changing to a bowden this weekend . .can you spare me a ft of the ptfe tube?
August 21, 2012 03:32AM
my rods arrived today, unexpectidly early! smiling smiley
September 03, 2012 08:33AM
My Build has begun.
[dustsreprap.blogspot.co.nz]
Edited 1 time(s). Last edit at 09/04/2012 05:13AM by Dust.
September 06, 2012 02:56AM
Cool to see other NZ'ers are making Rostocks too. My delta 3D printer will be my first 3D printer so I'm having to make it on my CNC machine. It means I have to make the platform and carriages in a sort of long winded way but I think it should work out well.
Dust I was hoping you could tell me where you managed to find the teflon tube?
Check out my delta printer and see what you think!
September 06, 2012 03:12AM
Hi joshendy
Ive seen your blog before, and wanted to ask you questions about your CNC, like what exactly is that piece of steal you run your bearing on?
My teflon tube came from e-bay this store [stores.ebay.com] search for "teflon tube"
September 06, 2012 05:20PM
Awesome thanks for the link. My CNC router uses cncrouterparts' linear carriages and they run on 1/4" or 6mm cold rolled steel. It's important it is cold rolled because it has a more even thickness than hot rolled or normal steel. My 6mm thickness cold rolled steel only cost me around $80 here in Wellington from Acme Engineering.
September 09, 2012 03:03AM
September 16, 2012 06:03AM
My rostock has hit a snag...
The modified marlin firmware doesn't seem to want to work correctly on a Sanguinololu 1.3a
In particular the temperature reads 200C when it only 20C. Normal Marlin and Sprinter both read 20C...
Im suspecting something weird like a variable overflow... as the tempurature reading code is the same.
October 16, 2012 05:23AM
Might not be relevant but what atmega chip are u using on the sanguino board dust?
October 16, 2012 07:15AM
its a standard 644p, the code does fit in 64k, if you don't enable LCD support.
October 18, 2012 06:58AM
I'm going to have a crack at one of these. Based in Massey, West Auckland.
Looks easire to make than some of the other reprap designs.
October 26, 2012 08:42AM
Update about Rostock Firmware on Sanguinololu, basically it needs a 1284p chip
More details [dustsreprap.blogspot.co.nz]
And since I now have the Firmware sorted, the rostock took its first moves today
Short video [dustsreprap.blogspot.co.nz]
October 31, 2012 08:08AM
I'm building a Rostock here in West Auckland.
In the collecting the pieces phase.
So far I've ordered most of the hardware type bits.
Still to decide:
Type of extruder
Material for base
Where to get printed parts made.
All very exciting
November 02, 2012 04:14AM
Hi there,
I might be able to help you with the extrusions. Have a look at my thread on Openbeam
I would be very interested in seeing a Rostock being built with it. Also have a talk with Josh from [www.joshendy.net].
I am helping him with his Rostock build. He is very talented maker!!!
> bits.
> Still to decide:
> Type of extruder
> Material for base
> All very exciting
Protoneer.co.nz - Blog - [blog.Protoneer.co.nz]
Protoneer.co.nz - Shop - [shop.Protoneer.co.nz]
