New Wellington Builder
Posted by 41southrap
August 28, 2012 05:15AM
Hi all,
Colin here from Wellington. I've just rediscovered this 3D printing stuff and would like to build a Prusa. I see a few standard 'mods' in my interweb journey today, is there a recommended bunch of standard 'mods' that I could or should include in a first build?
Any help in getting locally manufactured parts and supplies would be much appreciated.
Cheers
Colin
Re: New Wellington Builder
August 28, 2012 06:13AM
Use linear bearings instead of bushes
__________________________________________________________________________
Experimenting in 3D in New Zealand
August 28, 2012 07:46AM
Have you had a look at nz parts sourcing guide in this forum ? Theres a lot of usefull info there . . .
August 28, 2012 07:53AM
The latest Mendel Prusa seems fairly bullet proof: Mendel Prusa on Github but there are numerous alternate parts on thingiverse.
_________________________________________________________________________________________
Richmond, New Zealand
Thingiverse ~ YouTube
August 28, 2012 05:08PM
Thanks, I was thinking I'll probably go for the Iteration 2 metric version, is that a wise choice? I'm only thinking metric because it's pretty easy to come by all that size stuff here.
Also has anyone used www.servocity.com for parts. I've used them for other projects and they have haeps of gears, pulleys, bearings etc etc.
Thanks again
Colin
August 28, 2012 05:14PM
Definatley go metric, Imperial is for the American market and really hard to do here
August 29, 2012 12:14AM
Probably best to stick with Reprap specialist for parts. A lot of the bits can be sourced locally from this site or with a little searching, just put up a wanted ad and see who rocks up. Hopefully someone in Wellys?
August 29, 2012 02:20AM
For a standard Prusa here is my list of Mods or options that you should consider.
Linear bearings.
Finer grade belts or my favourite synchroMesh cable (http://www.youtube.com/watch?v=ZdSNRCEeU64) from SDP who ship from USA
(Easier to align, less backlash)
Buy also some extra 8mm threaded rod, nuts and bolts for a brace. [www.thingiverse.com] You can print it yourself and retro fit it to your printer
(Printer frame will be sturdier, more stable at speed, less likely to misalign when moved)
Cooling fans for your hot end
(Improves the print quality for PLA and some ABS prints)
Cooling fan for your electronics
(Allows you to turn up the torque in the motors)
LCD, Rotary Encoder and SD card reader
(I use this on RAMPS and means I get unattended prints. More reliable than using computers to control ie sleep modes, shutdowns for updates etc)
That will get you pretty much at the optimum for the Prusa design IMHO.
August 29, 2012 02:38AM
Awesome info Blair - how come the price difference is so great between the two links you posted? the second one is freight free too.
August 29, 2012 02:47AM
What two links?
Oh PS.. Make sure that you dont use springs on your print bed as you see on earlier designs. There is no need for them and they just add backlash. If you look in the Youtube video above you can see how better to do it.
PPS I also should have mentioned make sure you spring for a heated print bed.
Edited 1 time(s). Last edit at 08/29/2012 02:50AM by Justblair.
August 29, 2012 03:48AM
Sorry, replied to the wrong thread smiling smiley too many pages open at once.
Anyone seen a 9" x 9" heated bed anywhere?
August 29, 2012 07:12PM
Heaps of great information - many thanks guys. thumbs up Justblair - thanks for your list, just what I was looking for smileys with beer
I'm heading down the RAMPS 1.4 route for the electronics - are there any pitfalls to that? I use a lot of Arduio stuff so it seems to make sense. I also like the sdcard and lcd options for PC-less operations. There is an eBay seller who has the whole RAMPS 1.4 electronics kit (including sdcard and the stepper driver modules) for USD$145, which beats anything I have seen locally. Unless of course one of you folks here has a deal going? grinning smiley
Cheers again
Colin.
August 30, 2012 04:51AM
If you are going to build a prusa, it may be worth waiting a month or so for when Josef Prusa has finally finished and published his book (search for reprap on bookdepository).
August 30, 2012 04:53AM
... oh yeahdrinking smiley, and check out the "Wellington reprap meeting" thread.
