Holes in prints
August 08, 2013 01:20AM
Hey people
I keep having some problems with my print only seems to happen on some prints and gears no matter what gears be they thingiverse files or prusa originals
Using sprinter firmware and slic3r
Ramps 1.4
Happens on all different infill settings
3 perimeters 3 layers top and bottom
Solid objects like extruder bodies etc come out fine any help appreciated
Thanks to wired1 as built his OB1 prism excellent build far better than my mendel v2
open | download - image.jpg (264.3 KB)
Re: Holes in prints
August 08, 2013 04:06AM
You need to use less outlines to leave room for the infill. I use single outlines for gears.
Re: Holes in prints
August 08, 2013 04:43AM
Just tried with 1 perimeter and it did zero fill for the teeth centre of gear was perfect but teeth were an empty ring on the outside???
Re: Holes in prints
August 08, 2013 05:19AM
Another photo?
_______________________________________
Waitaki 3D Printer
Re: Holes in prints
August 08, 2013 05:26PM
Photo added this was removed from bed when it started to print second layer
open | download - image.jpg (145.3 KB)
Re: Holes in prints
August 08, 2013 09:13PM
Is this "Thing:19277"?
I had a look at that one and sliced it with 0.99 then checked it with the Repetier G-code viewer and 1st layer looks ok. Did you check it to see what you get in the viewer?
Waitaki 3D Printer
Re: Holes in prints
August 08, 2013 10:40PM
I suspect you meant Thing:19227 rather than Thing:19277?
(Just in case someone else wanted to look it up)
Re: Holes in prints
August 09, 2013 01:54AM
Yes, your dead right Revva - well spotted!
Waitaki 3D Printer
Re: Holes in prints
August 09, 2013 02:48AM
Yes that's the one
Did a bit of reading around and did read that 0.9.10b has a few bugs so cleaned out all slicer files downloaded 0.7.2b (read it was a stable version) and printed again was very near perfect so not sure if its that version or if I had corrupt file will have to experiment some more to see
Re: Holes in prints
December 11, 2013 01:51AM
Your gears layer thick are too big. Try to reduce it .
