3mm Steel laser cutting?
Posted by Dust
August 17, 2014 05:39AM
Any one know of anywhere in NZ that can do 3mm steel laser cutting?
A steel I3 is appealing
Re: 3mm Steel laser cutting?
August 18, 2014 04:54PM
I don't think 3mm is a huge ask in laser cutting terms, but that might just be because I only deal with industrial laser cutters.
Two in east Auckland I've used are
[hi-techmetals.co.nz]
[www.metalskillsltd.com]
They routinely cut mild steel thicker than that for us.
August 22, 2014 05:39PM
I would look at water jet cutting.
I have just had some Openbeam angle brackets cut in Rotorua out of 2mm aluminium. Designing and building an CoreXY Openbeam Reprap.
You don't get heat warping with water jet cutters.
Makes excellent cuts, only thing we found that cutting small 3mm holes that the aluminium is a bit soft and it blows the hole slightly bigger on one side, doesn't happen with harder steels.
August 27, 2014 06:13AM
I’ve gone another way... went the lazy route and ordered one
more info here
