Cut2D-Postprozessor für Lasercutter February 18, 2016 04:37PM |
+ SPARKCUBE-LASER - Vectric machine output configuration file
+ History
+ Who When What
+ okrim 02/05/2016 M106/M107
+ 02/05/2016 Spindelspeed = Laser Intesität M106 [S]
+ okrim 02/06/2016 Kommentierungen eingefügt
+ Laser Control Commands
+ Change these to match your needs
+ M106 S255 = Laser Power On
+ M107 = Laser Power Off
+ S0 = Laser intensity 0%
+ S25 = Laser intensity 10%
+ S255 = Laser intensity 100%
+ 0.50mm Pass-Depth = Schnitttiefe Laser aus Tool-Editor
+ [F] Feed-Rate aus Tool-Editor
+ [S] Spindel-Speed aus Tool-Editor
+ [ZH] HOME-POSITON aus Material-Setup anfahren
+ Z40.000 = Rapid clearence gap aus Material-Setup
+ Cut Depth aus 2D Profile Toolpath : Pass-Depth = Anzahl Passes
+ How to use
+ Name file: SPARKCUBE-LASER-mm.pp
+ Save file to Post Processor dir (example below)
+ C:\Program Files (x86)\Cut2D V1\PostP
POST_NAME = "SPARKCUBE-LASER-V3(mm) (*.gcode)"
FILE_EXTENSION = "gcode"
+ Rememeber you are working in MM
UNITS = "MM"
+ Line terminating characters
LINE_ENDING = "[13][10]"
+ Block numbering
LINE_NUMBER_START = 0
LINE_NUMBER_INCREMENT = 10
LINE_NUMBER_MAXIMUM = 999999
+ Formating for variables
VAR LINE_NUMBER = [N|A|N|1.0]
VAR SPINDLE_SPEED = [S|A|S|1.0]
VAR FEED_RATE = [F|C|F|1.1]
VAR X_POSITION = [X|C|X|1.4]
VAR Y_POSITION = [Y|C|Y|1.4]
VAR Z_POSITION = [Z|C|Z|1.4]
VAR ARC_CENTRE_I_INC_POSITION = [I|A|I|1.4]
VAR ARC_CENTRE_J_INC_POSITION = [J|A|J|1.4]
VAR X_HOME_POSITION = [XH|A|X|1.4]
VAR Y_HOME_POSITION = [YH|A|Y|1.4]
VAR Z_HOME_POSITION = [ZH|A|Z|1.4]
+ Block definitions for toolpath output
+ Commands output at the start of the file
begin HEADER
"( [TOOLPATH_NAME] )"
"( SPARKCUBE-LASER Postprocessor )"
"( SPARKCUBE-LASER - Vectric CUT2D)"
+"+ Laser Control Commands"
+"+ Change these to match your needs"
+"+ M106 S255 = Laser Power On"
+"+ M107 = Laser Power Off"
+"+ S0 = Laser intensity 0%"
+"+ S25 = Laser intensity 10%"
+"+ S255 = Laser intensity 100%"
+"+ 0.50mm Pass-Depth = Schnitttiefe Laser aus Tool-Editor"
+"+ (F) [F] Feed-Rate aus Tool-Editor"
+"+ (S) [S] Spindel-Speed aus Tool-Editor = Laser 0-255"
+"+ (ZH)[ZH] HOME-POSITON aus Material-Setup "
+"+ Z40.000 = Rapid clearence gap aus Material-Setup"
+"+ Cut Depth aus 2D Profile Toolpath : Pass-Depth = Anzahl Passes"
+ kalt Extruieren
+"(++ kalt exruieren erlauben ++)"
"M302"
+ Absaugung Lüfter einschalten
+"(++ Absaugung und Lüfter einschalten ++)"
+ M106 S500 ; Absaugung / Lüfter 90%
+ Set Units to MM
+"(++ Set Units to MM ++)"
"G21"
+ G90 Absolute Positionen
+"(++ G90 Absolute Positionen ++)"
"G90"
+ Aktuelle Posistion Kreuzlinienlaser ist Werkstueck-Nullpunkt
+"(++ Aktuelle Position Kreuzlinienlaser = Werkstück Nullpunkt++ )"
"G92 X0 Y0 Z0"
+ Laser 5mm anheben
+"(++ Laser 5mm anheben ++)"
"G0 X0 Y0 Z5 F100 "
+ Laserpunkt anfahren hier Versatzwerte Kreuzlaser eintragen
+"(++ X Y Versatz Kreuzlinienlaser anfahren ++ )"
"G0 X-37.15 Y52.15 F3000"
+ Werstueckoberflaeche anfahren
+"(++ Werstueckoberflaeche anfahren ++)"
"G0 Z0 F1000"
+ Aktuelle Position wird auf NULL gesetzt
+"(++ Aktuelle Position wird auf NULL gesetzt ++)"
"G92 X0 Y0 Z0"
+ HOME-POSITON aus Material-Setup anfahren
+"(++ HOME-POSITON aus Material-Setup anfahren ++ )"
"G0 [XH] [YH] [ZH] F3000"
+ Laser auf 50% Leistung
+"(++ Lasser 50% ON ++ )"
+"M106 S127"
+"G04 P0"
+"(++ Verfahrwege LASER ++ )"
+ Commands output for rapid moves
begin RAPID_MOVE
+ S25 Set laser output to 10% for rapid --> M 106 S255=100% ändern ???
+"(++ Laser Positionierbewegung ++ )"
"M106 S25"
"G0 [X] [Y] [Z] F3000"
+ Commands output for the first feed rate move
begin FIRST_FEED_MOVE
+ M106 S255 sets laser power to full to cut
+ G04 P10. Dwells for 10 seconds to allow cut to start
+"(++ LASER-CUTTING ++ )"
"M106 [S]"
"G04 P0"
"G1 [X] [Y] [Z] [F]"
+ Commands output for feed rate moves
begin FEED_MOVE
"G1 [X] [Y] [Z]"
+ Commands output for the first clockwise arc move
begin FIRST_CW_ARC_MOVE
"G2 [X] [Y] [I] [J] [F]"
+ Commands output for clockwise arc move
begin CW_ARC_MOVE
"G2 [X] [Y] [I] [J]"
+ Commands output for the first counterclockwise arc move
begin FIRST_CCW_ARC_MOVE
"G3 [X] [Y] [I] [J] [F]"
+ Commands output for counterclockwise arc move
begin CCW_ARC_MOVE
"G3 [X] [Y] [I] [J]"
+ Commands output at the end of the file
begin FOOTER
+"(++ Laser auf 10% Power ++ )"
"M106 S25"
+ M107 turns off the Laser
+"(++ M107 turns off the Laser ++ )"
"M107"
+ HOME-POSITON aus Printer-Setup anfahren --> Z=HOME-POSITON Printer-Setup
+"(++ HOME-POSITON aus Printer-Setup anfahren ++ )"
"G0 [XH] [YH] Z220 F3000"
+ Program End
( Profile 1 )
M302
G21
G90
G92 X0 Y0 Z0
G0 X0 Y0 Z5 F100
G0 Z0 F1000
G92 X0 Y0 Z0
G0 X0.0000 Y0.0000 Z0.1000 F3000
M106 S25
G0 X0.0000 Y20.0000 Z0.1000 F3000
M106 S250
G04 P0
G1 Z-0.5000 F3000.0
G2 X20.0000 Y0.0000 I0.0000 J-20.0000 F960.0
G2 X0.0000 Y-20.0000 I-20.0000 J-0.0000
G2 X-20.0000 Y0.0000 I-0.0000 J20.0000
G2 X0.0000 Y20.0000 I20.0000 J0.0000
M106 S250
G04 P0
G1 Z-1.0000 F3000.0
M106 S25
G0 Z0.1000 F3000
M106 S25
G0 X-25.0000 Y-25.0000 F3000
M106 S250
G04 P0
G1 Z-0.5000 F3000.0
M106 S250
G04 P0
G1 X25.0000 F960.0
G1 Y25.0000
G1 X-25.0000
G1 Y-25.0000
M106 S250
G04 P0
G1 Z-1.0000 F3000.0
M106 S250
G04 P0
G1 X25.0000 F960.0
G1 Y25.0000
G1 X-25.0000
G1 Y-25.0000
M106 S25
G0 Z0.1000 F3000
M106 S25
M107
G0 X0.0000 Y0.0000 Z220 F3000
Re: Cut2D-Postprozessor für Lasercutter February 19, 2016 04:16AM |
Re: Cut2D-Postprozessor für Lasercutter February 19, 2016 04:37AM |
Admin Registered: 19 years ago Posts: 14,205 |
Re: Cut2D-Postprozessor für Lasercutter February 19, 2016 04:23PM |
Re: Cut2D-Postprozessor für Lasercutter February 22, 2016 02:51AM |
Re: Cut2D-Postprozessor für Lasercutter February 22, 2016 03:05AM |
Re: Cut2D-Postprozessor für Lasercutter February 22, 2016 03:37AM |
Re: Cut2D-Postprozessor für Lasercutter February 22, 2016 05:08AM |
Re: Cut2D-Postprozessor für Lasercutter February 24, 2016 05:03PM |
.wie wird die Fläche vom pocket toolpath ausgefüllt? Zeilenweise?
Re: Cut2D-Postprozessor für Lasercutter February 24, 2016 05:40PM |
Re: Cut2D-Postprozessor für Lasercutter February 25, 2016 04:57AM |
Re: Cut2D-Postprozessor für Lasercutter February 28, 2016 06:24PM |
Re: Cut2D-Postprozessor für Lasercutter February 28, 2016 06:46PM |
Re: Cut2D-Postprozessor für Lasercutter March 01, 2016 05:41PM |
, aber ich kann Dich verstehen.
Re: Cut2D-Postprozessor für Lasercutter March 01, 2016 11:44PM |
okrim
Kann man den einfach abgreifen, also lt. pins.h zB. E0_STEP_PIN 26(Ramps) ?
| Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Cut2D-Postprozessor für Lasercutter March 02, 2016 02:13AM |
Re: Cut2D-Postprozessor für Lasercutter March 02, 2016 06:06PM |
Re: Cut2D-Postprozessor für Lasercutter March 02, 2016 07:02PM |
Re: Cut2D-Postprozessor für Lasercutter March 04, 2016 06:11PM |
Re: Cut2D-Postprozessor für Lasercutter March 04, 2016 07:24PM |
Re: Cut2D-Postprozessor für Lasercutter March 04, 2016 08:05PM |
in Reihe in Verbindung mit den vorhandenen Z-Dioden im µController.
