confused smiley [STRANGE] echogrinning smileyEBUG: ?p??????a?@??
Posted by ianmcmill
August 04, 2016 12:37PM
Hello,
Configuration:
  • Controller: Arduino + RAMPS 1.4
  • Firmware: #define SHORT_BUILD_VERSION "1.1.0-RC5"
  • Direct USB prints (for years)
  • No limit switches. All soft limited. Since...ever.
after several successfull prints with #define SHORT_BUILD_VERSION "1.1.0-RC5" I wonder what this strange debug message wants to tell me.
It has been there since I have flashed the firmware but the prints work fine. Although I am getting "thermal runaway protection" halts more often after I have switched from a Teensylu to an Arduino + Ramps 1.4. I've already set the protection values to four times the default values (40sec/4°C for extruder). Thermistor is "sealed" off inside the alu heating block with thermal grease. Never had that issue with Teensylu with which I used "always on" fan for printed parts. Now I have switched to auto fan control with a max value of 70% using a radial fan and getting these protectio triggers. I am not sure if that has something to do with the strange debug output posted below.
But back to topic:
What is this??
I tried different baudrates in the firmware and uploaded them without improvement (250000;115200)
btw I really like the smileys injection...
18:27:36.398 : Printer reset detected - initalizing
18:27:36.398 : start
18:27:36.402 : echo: External Reset
18:27:36.402 : Marlin 1.1.0-RC5
18:27:36.406 : echo: Last Updated: 2016-04-01 12:00 | Author: (none, default config)
18:27:36.410 : Compiled: Aug  4 2016
18:27:36.414 : echo: Free Memory: 4995  PlannerBufferBytes: 1232
18:27:36.418 : echo:V23 stored settings retrieved (396 bytes)
18:27:36.422 : echoconfused smileyteps per unit:
18:27:36.426 : echo:  M92 X100.61 Y100.32 Z3996.00 E790.00
18:27:36.427 : echo:Maximum feedrates (mm/s):
18:27:36.430 : echo:  M203 X350.00 Y350.00 Z3.00 E50.00
18:27:36.435 : echo:Maximum Acceleration (mm/s2):
18:27:36.435 : echo:  M201 X900 Y900 Z50 E1000
18:27:36.443 : echo:Accelerations: P=printing, R=retract and T=travel
18:27:36.443 : echo:  M204 P1000.00 R2000.00 T3000.00
18:27:36.459 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s),  Z=maximum Z jerk (mm/s),  E=maximum E jerk (mm/s)
18:27:36.463 : echo:  M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
18:27:36.467 : echo:Home offset (mm):
18:27:36.467 : echo:  M206 X0.00 Y0.00 Z0.00
18:27:36.472 : echotongue sticking out smileyID settings:
18:27:36.476 : echo:  M301 P22.20 I1.08 D114.00 C100.00 L20
18:27:36.476 : echo:Filament settings: Disabled
18:27:36.480 : echo:  M200 D3.00
18:27:36.480 : echo:  M200 D0
18:27:36.783 : FIRMWARE_NAME:Marlin 1.1.0-RC5 From Archive SOURCE_CODE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:3D Printer EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
18:27:36.791 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0 Y:0 Z:0
18:27:36.807 : echogrinning smileyEBUG: ?p??????a?@??P??`??p??????V?@??P??`??p??????K?/????????#A????|P??`??p??????a?@??P??`??p??????V?@??P??`??p??????K?/????????#A????
18:27:36.807 : echo:Active Extruder: 0
18:27:36.828 : echogrinning smileyEBUG: ?p??????a?@??P??`??p??????V?@??P??`??p??????K?/????????#A????|P??`??p??????a?@??P??`??p??????V?@??P??`??p??????K?/????????#A????
18:27:36.828 : echo:Active Extruder: 0
Blog: Capotexl
Filament Factory - How to build your own cheap filament extruder
Frankenstein Laser Engraver
Make the world a better place
open | download - Configuration.h (40.4 KB)
open | download - Configuration_adv.h (27.5 KB)
