z-axis probe won't store [1.1.0 RC7] August 10, 2016 10:09AM |
#define DELTA #if ENABLED(DELTA) #define DELTA_SEGMENTS_PER_SECOND 200 #define DELTA_DIAGONAL_ROD 188.5 // mm #define DELTA_SMOOTH_ROD_OFFSET 140.3 // mm #define DELTA_EFFECTOR_OFFSET 33.0 // mm #define DELTA_CARRIAGE_OFFSET 22.0 // mm #define DELTA_RADIUS (DELTA_SMOOTH_ROD_OFFSET-(DELTA_EFFECTOR_OFFSET)-(DELTA_CARRIAGE_OFFSET)) #define DELTA_PRINTABLE_RADIUS 80.0 #endif #define USE_ZMIN_PLUG // a Z probe #define USE_XMAX_PLUG #define USE_YMAX_PLUG #define USE_ZMAX_PLUG #define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors #if DISABLED(ENDSTOPPULLUPS) #endif #define X_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Y_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Z_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define X_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Y_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Z_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Z_MIN_PROBE_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define X_PROBE_OFFSET_FROM_EXTRUDER 0.0 // X offset: -left +right [of the nozzle] #define Y_PROBE_OFFSET_FROM_EXTRUDER 10.0 // Y offset: -front +behind [the nozzle] #define Z_PROBE_OFFSET_FROM_EXTRUDER -6.8 // Z offset: -below +above [the nozzle] #define XY_PROBE_SPEED 4000 #define Z_PROBE_SPEED_FAST HOMING_FEEDRATE_Z #define Z_PROBE_SPEED_SLOW (Z_PROBE_SPEED_FAST / 2) #define Z_PROBE_ALLEN_KEY #if ENABLED(Z_PROBE_ALLEN_KEY) #define Z_PROBE_ALLEN_KEY_DEPLOY_1_X 56.0 #define Z_PROBE_ALLEN_KEY_DEPLOY_1_Y 86.0 #define Z_PROBE_ALLEN_KEY_DEPLOY_1_Z 100.0 #define Z_PROBE_ALLEN_KEY_DEPLOY_1_FEEDRATE XY_PROBE_SPEED #define Z_PROBE_ALLEN_KEY_DEPLOY_2_X 36.0 #define Z_PROBE_ALLEN_KEY_DEPLOY_2_Y 83.0 #define Z_PROBE_ALLEN_KEY_DEPLOY_2_Z 100.0 #define Z_PROBE_ALLEN_KEY_DEPLOY_2_FEEDRATE (XY_PROBE_SPEED)/2 #define Z_PROBE_ALLEN_KEY_DEPLOY_3_X 0.0 #define Z_PROBE_ALLEN_KEY_DEPLOY_3_Y 0.0 #define Z_PROBE_ALLEN_KEY_DEPLOY_3_Z 100.0 #define Z_PROBE_ALLEN_KEY_DEPLOY_3_FEEDRATE XY_PROBE_SPEED #define Z_PROBE_ALLEN_KEY_STOW_1_X 0.0 // Move the probe into position #define Z_PROBE_ALLEN_KEY_STOW_1_Y -98.0 #define Z_PROBE_ALLEN_KEY_STOW_1_Z 10.0 #define Z_PROBE_ALLEN_KEY_STOW_1_FEEDRATE XY_PROBE_SPEED #define Z_PROBE_ALLEN_KEY_STOW_2_X 0.0 // Push it down #define Z_PROBE_ALLEN_KEY_STOW_2_Y -98.0 #define Z_PROBE_ALLEN_KEY_STOW_2_Z -2.0 #define Z_PROBE_ALLEN_KEY_STOW_3_X 0.0 // Move it up to clear #define Z_PROBE_ALLEN_KEY_STOW_3_Y -98.0 #define Z_PROBE_ALLEN_KEY_STOW_3_Z 50.0 #define Z_PROBE_ALLEN_KEY_STOW_3_FEEDRATE XY_PROBE_SPEED #define Z_PROBE_ALLEN_KEY_STOW_4_X 0.0 #define Z_PROBE_ALLEN_KEY_STOW_4_Y 0.0 #define Z_PROBE_ALLEN_KEY_STOW_4_Z Z_PROBE_ALLEN_KEY_STOW_3_Z #define Z_PROBE_ALLEN_KEY_STOW_4_FEEDRATE XY_PROBE_SPEED #endif // Z_PROBE_ALLEN_KEY #define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN #define Z_PROBE_DEPLOY_HEIGHT 50 // Raise to make room for the probe to deploy / stow #define Z_PROBE_TRAVEL_HEIGHT 15 // Raise between probing points. #define Z_PROBE_OFFSET_RANGE_MIN -20 #define Z_PROBE_OFFSET_RANGE_MAX 20 #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 // For all extruders #define DISABLE_X false #define DISABLE_Y false #define DISABLE_Z false #define DISABLE_E false // For all extruders #define DISABLE_INACTIVE_EXTRUDER true //disable only inactive extruders and keep active extruder enabled #define INVERT_X_DIR false // DELTA does not invert #define INVERT_Y_DIR false #define INVERT_Z_DIR false #define INVERT_E0_DIR true #define INVERT_E1_DIR false #define INVERT_E2_DIR false #define INVERT_E3_DIR false #define X_HOME_DIR 1 // deltas always home to max #define Y_HOME_DIR 1 #define Z_HOME_DIR 1 #define min_software_endstops false // If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops false // If true, axis won't move to coordinates greater than the defined lengths below. #define X_MIN_POS -(DELTA_PRINTABLE_RADIUS) #define Y_MIN_POS -(DELTA_PRINTABLE_RADIUS) #define Z_MIN_POS 0 #define X_MAX_POS DELTA_PRINTABLE_RADIUS #define Y_MAX_POS DELTA_PRINTABLE_RADIUS #define Z_MAX_POS MANUAL_Z_HOME_POS #define AUTO_BED_LEVELING_FEATURE // Delete the comment to enable (remove // at the start of the line) #if ENABLED(AUTO_BED_LEVELING_FEATURE) #define AUTO_BED_LEVELING_GRID // Deltas only support grid mode. #if ENABLED(AUTO_BED_LEVELING_GRID) #define DELTA_PROBEABLE_RADIUS (DELTA_PRINTABLE_RADIUS - 10) #define LEFT_PROBE_BED_POSITION -(DELTA_PROBEABLE_RADIUS) #define RIGHT_PROBE_BED_POSITION DELTA_PROBEABLE_RADIUS #define FRONT_PROBE_BED_POSITION -(DELTA_PROBEABLE_RADIUS) #define BACK_PROBE_BED_POSITION DELTA_PROBEABLE_RADIUS #define MIN_PROBE_EDGE 10 // The Z probe minimum square sides can be no smaller than this. #define AUTO_BED_LEVELING_GRID_POINTS 9 #else // !AUTO_BED_LEVELING_GRID #define ABL_PROBE_PT_1_X 15 #define ABL_PROBE_PT_1_Y 180 #define ABL_PROBE_PT_2_X 15 #define ABL_PROBE_PT_2_Y 20 #define ABL_PROBE_PT_3_X 170 #define ABL_PROBE_PT_3_Y 20 #endif // !AUTO_BED_LEVELING_GRID #endif // AUTO_BED_LEVELING_FEATURE #define BED_CENTER_AT_0_0 #define MANUAL_Z_HOME_POS 168.3 // Distance between the nozzle to printbed after homing #define Z_SAFE_HOMING #if ENABLED(Z_SAFE_HOMING) #define Z_SAFE_HOMING_X_POINT ((X_MIN_POS + X_MAX_POS) / 2) // X point for Z homing when homing all axis (G28). #define Z_SAFE_HOMING_Y_POINT ((Y_MIN_POS + Y_MAX_POS) / 2) // Y point for Z homing when homing all axis (G28). #endif #define HOMING_FEEDRATE_Z (60*60)
Re: z-axis probe won't store [1.1.0 RC7] August 11, 2016 07:40AM |
