Wrong origin after autobed leveling
Posted by Sicon
October 01, 2016 01:25PM
Hello! I always used a sensor in the back-left from the nozzle (negative offset for X_PROBE_OFFSET_FROM_EXTRUDER and Y_PROBE_OFFSET_FROM_EXTRUDER) and all worked fine, now I change the sensor mount and it's aligned on the right of the nozzle so i set Y_PROBE_OFFSET_FROM_EXTRUDER=0 and X_PROBE_OFFSET_FROM_EXTRUDER=35 (sensor is 3.5 cm from the nozzle) and I have a problem with the origin when I print. The homing and the bed leving procedure are fine and scans at the right points, but when I start a print the origin shifts perfectly 35mm on the right so it's a little strange smiling smiley , is there something to change in marlin to fix this?
Thank you
Voronix Core XY (custom model): Radds 1.6 (DRV8825) - Nextion 7" - E3d Titan + Hotend E3d V6 Direct - MK4DUO 4.3.3
Re: Wrong origin after autobed leveling
October 01, 2016 03:06PM
Sound like you didn't change the probe positions. If it hits an endstop during probing, the 0 for that axis shifts.
October 01, 2016 04:35PM
Just checked: the probing points (where the probe does the scan) are as expected (as I set in marlin configuration) and no ones pull the mechanical end stops, do you know if there is something about it in the configuration.h of the marlin?
