Compiling Marlin on Raspberry Pi (Raspbian Jessie) December 11, 2016 05:32PM |
make: *** No rule to make target 'applet/wiring.o', needed by 'applet/Marlin.elf'. Stop.
Re: Compiling Marlin on Raspberry Pi (Raspbian Jessie) December 11, 2016 10:58PM |
Admin Registered: 13 years ago Posts: 6,995 |
Re: Compiling Marlin on Raspberry Pi (Raspbian Jessie) December 12, 2016 03:09AM |
Dust
the Makefile is very very badly maintained, as most people use the GUI
Also most don't compile on Raspi3, are you just a glutton for punishment?
regardless, if you load this in the GUI you still error
"Versions of Arduino IDE prior to 1.6.8 are no longer supported, please update your toolkit."
So basically this is now impossible to compile on a raspburry pi with standard packages (which is still 1.0.5, if i'm reading that version correctly)
Now there is the experimental "Linux ARM (experimental)" on the arduino download page. You could try that
Re: Compiling Marlin on Raspberry Pi (Raspbian Jessie) April 24, 2017 01:46PM |
Re: Compiling Marlin on Raspberry Pi (Raspbian Jessie) April 24, 2017 02:08PM |
