I have an “old” printer (Bukobot circa 2014) which has an Azteeg X3 board running Marlin from about that same period. I don’t have the code that the board was installed with, but I do have the “documented” changes made when the Marlin was configured. I have been able to integrate the previous documented changes and figure out a few others to get my printer almost working:
- X movement works correctl.y (+,-,home)
- Y movement works correctl.y (+,-,home)
- Z movement works correctl.y (+,-,home)
- Hot end appears to work hitting and maintaining temp. (no real confirmation, my IR temp gun is on order)
- Bed temps appear to work hitting and also maintaining set temps.
I’ve been using the latest version Arduino IDE to flash my printer and Proterface to test on macOS 10.12.
The next problem I’m trying to overcome is extrusion...
In Pronterface, whenever I select “Extrude”, Pronterface responds with "Extruding 1.000000mm of filament.” but the printer actually retracts.
When I press “Retract”, Pronterface responds with: "Reversing 1.000000mm of filament.”, but the printer extrudes.
Now, this was a working printer before the update so none of the wiring has changed, just the firmware.
What setting do I change to invert extruder operation?
[edit] corrected the "Extrude" response from Pronterface. (copy/paste error).
Edited 2 time(s). Last edit at 08/27/2017 01:50PM by gdahilig.
open |
download -
Configuration_adv.h
(56.7 KB)
