Happy New Year!
I've been banging my head against the wall trying to get my BLTouch setup. This is what the terminal on Octoprint outputs when I start up:
Recv: ErrorTOP called because of BLTouch error - restart with M999
Changing monitoring state from 'Connecting' to 'Error: STOP called because of BLTouch error - restart with M999
Recv: Errorrinter stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
Recv: ok
Changing monitoring state from 'Error: STOP called because of BLTouch error - restart with M999
' to 'Offline'
I'm able to restart the serial connection and run Gcode commands. The following commands run as they should:
M280 P0 S10 ; pushes the pin down
M280 P0 S90 ; pulls the pin up
M280 P0 S120 ; Self test – keeps going until you do pin up/down or release alarm
M280 P0 S160 ; Release alarm
Attached is my configuration file. Any help on eliminating the errors would be greatly appreciated.
Thank you very much.
Loren
