Adding menu for Laser cut calibration March 23, 2018 07:08PM |
"G90\nG21\nG1 F5000\nG1 X0 Y20\nG4 P0\nM106 S%i\nG4 P0\nG1 F%i\nG1 X20 Y20\nG1 X20 Y0\nG1 X0 Y0\nG1 X0 Y20\nG4 P0\nM107 S0\nG1 F5000\nG1 X0 Y0"
void lcd_lasercutprepare_menu(); static int lasertest_power = 255; //default values for power static int lasertest_speed = 150; //default value for speed static char lasertest_gcode[150];
MENU_ITEM(submenu, _UxGT("Calibrate Laser cut"), lcd_lasercutprepare_menu);
void lasertest_callback(){ sprintf_P(lasertest_code, PSTR("G90\nG21\nG1 F5000\nG1 X0 Y20\nG4 P0\nM106 S%i\nG4 P0\nG1 F%i\nG1 X20 Y20\nG1 X20 Y0\nG1 X0 Y0\nG1 X0 Y20\nG4 P0\nM107 S0\nG1 F5000\nG1 X0 Y0"), lasertest_power, lasertest_speed); enqueue_and_echo_commands_P(lasertest_code); } void lcd_lasercutprepare_menu() { START_MENU(); MENU_BACK(MSG_PREPARE); MENU_ITEM(gcode, _UxGT("auto home head"), PSTR("G28\nG1 Z50")); //for initializing the laser head position at (0,0,50) MENU_MULTIPLIER_ITEM_EDIT(int3, _UxGT("Power: "), &lasertest_power, 0, 255); //for editing the power of the laser MENU_MULTIPLIER_ITEM_EDIT(int3, _UxGT("Speed: "), &lasertest_speed, 0, 5000); //for editing the speed MENU_ITEM(gcode, _UxGT("Z.offset -= 0.1"), PSTR("G91\nG1 Z-0.1\nG90")); //for move Z axis a little to try another pass MENU_ITEM(function, _UxGT("--Run test--"), lasertest_callback); //for running one pass of the calibration test END_MENU(); }
Re: Adding menu for Laser cut calibration March 24, 2018 07:09PM |
--- ultralcd.cpp 2018-03-24 23:56:39.000000000 +0100 +++ ultralcd.cpp 2018-03-24 23:42:23.000000000 +0100 @@ -187,6 +187,10 @@ void lcd_control_temperature_menu(); void lcd_control_motion_menu(); + void lcd_lasercutprepare_menu(); + static int lasertest_power = 255; //default cut laser power + static int lasertest_speed = 200; //default cut speed + #if DISABLED(SLIM_LCD_MENUS) void lcd_control_temperature_preheat_material1_settings_menu(); void lcd_control_temperature_preheat_material2_settings_menu(); @@ -2574,6 +2578,8 @@ // MENU_BACK(MSG_MAIN); + MENU_ITEM(submenu, _UxGT("Calibrate Laser cut"), lcd_lasercutprepare_menu); + // // Move Axis @@ -3185,6 +3191,39 @@ END_MENU(); } +/* + * Callback called on push of [run one pass] menu entry. + * One pass consist on the laser cutting of a 20mm square + * Beware that in my configuration, I am using M106 and M107 to drive laser power. + * If you are using others commands (like M4 or M5, substitute it in the following gcode). + */ +void lasertest_callback(){ + char s[15]; + enqueue_and_echo_commands_P(PSTR("G90\nG21")); + sprintf_P(s, PSTR("M106 S%i"), lasertest_power); lcd_enqueue_command(s); + sprintf_P(s, PSTR("G1 F%i"), lasertest_speed); lcd_enqueue_command(s); + enqueue_and_echo_commands_P(PSTR("G1 X0 Y20\nG1 X20 Y20\nG1 X20 Y0\nG1 X0 Y0\nM107 S0")); +} + +/* + * MENU for calibrating laser cut for current material. + * The goal of this menu is to bring tools for determine the correct power/speed/nb of passes for a given material. + * Following entries are displayed in this menu: + * - Auto home +50 : the head is first homed then laser head goes up 50mm to its focalized position. + * - Disable steppers : if you want to move the bed by hand to place the laser head on an arbitrary position. + * - Speed (0-999 mm/min) : test speed + * - Power (0-255) : test power + * - Z.offset -= 0.1 : Clicking on this menu entry makes Z axis to move 0.1mm down + * - Start square test : Actually starts the test = the gcode of a 20mm^2 square + */ +void lcd_lasercutprepare_menu() { + START_MENU(); + MENU_BACK(MSG_PREPARE); + MENU_ITEM(gcode, _UxGT("Auto home +50"), PSTR("G28\nG1 Z50")); + MENU_ITEM(gcode, MSG_DISABLE_STEPPERS, PSTR("M84")); + MENU_MULTIPLIER_ITEM_EDIT(int3, _UxGT("Power: "), &lasertest_power, 0, 255); + MENU_MULTIPLIER_ITEM_EDIT(int3, _UxGT("Speed: "), &lasertest_speed, 0, 999); + MENU_ITEM(gcode, _UxGT("Z.offset -= 0.1"), PSTR("G91\nG1 Z-0.1\nG90")); + MENU_ITEM(function, _UxGT("[Run one pass]"), lasertest_callback); + END_MENU(); + } + /** * * "Control" submenu
