ERR:MINTEMP BED February 27, 2019 10:49AM |
Re: ERR:MINTEMP BED February 27, 2019 03:24PM |
Re: ERR:MINTEMP BED February 27, 2019 05:30PM |
Re: ERR:MINTEMP BED February 28, 2019 06:18AM |
//#define PIDTEMP
Arduino:1.8.8 (Windows 10), Scheda:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)" In file included from sketch\ConfigurationStore.cpp:1:0: sketch\ConfigurationStore.cpp: In function 'void Config_PrintSettings()': ConfigurationStore.cpp:215:42: error: 'unscalePID_i' was not declared in this scope SERIAL_ECHOPAIR(" I", unscalePID_i(bedKi)); ^ sketch\Marlin.h:93:68: note: in definition of macro 'SERIAL_ECHOPAIR' #define SERIAL_ECHOPAIR(name,value) (serial_echopair_P(PSTR(name),(value))) ^ ConfigurationStore.cpp:216:42: error: 'unscalePID_d' was not declared in this scope SERIAL_ECHOPAIR(" D", unscalePID_d(bedKd)); ^ sketch\Marlin.h:93:68: note: in definition of macro 'SERIAL_ECHOPAIR' #define SERIAL_ECHOPAIR(name,value) (serial_echopair_P(PSTR(name),(value))) ^ sketch\Marlin_main.cpp: In function 'void process_commands()': Marlin_main.cpp:5128:59: error: 'scalePID_i' was not declared in this scope if(code_seen('I')) bedKi = scalePID_i(code_value()); ^ Marlin_main.cpp:5129:59: error: 'scalePID_d' was not declared in this scope if(code_seen('D')) bedKd = scalePID_d(code_value()); ^ In file included from sketch\Marlin_main.cpp:30:0: Marlin_main.cpp:5136:43: error: 'unscalePID_i' was not declared in this scope SERIAL_PROTOCOL(unscalePID_i(bedKi)); ^ sketch\Marlin.h:65:44: note: in definition of macro 'SERIAL_PROTOCOL' #define SERIAL_PROTOCOL(x) (MYSERIAL.print(x)) ^ Marlin_main.cpp:5138:43: error: 'unscalePID_d' was not declared in this scope SERIAL_PROTOCOL(unscalePID_d(bedKd)); ^ sketch\Marlin.h:65:44: note: in definition of macro 'SERIAL_PROTOCOL' #define SERIAL_PROTOCOL(x) (MYSERIAL.print(x)) ^ exit status 1 temperature.cpp:70:30: error: 'PID_dT' was not declared in this scope float bedKi=(DEFAULT_bedKi*PID_dT); ^ temperature.cpp:71:30: error: 'PID_dT' was not declared in this scope float bedKd=(DEFAULT_bedKd/PID_dT); ^ sketch\temperature.cpp: In function 'void PID_autotune(float, int, int)': temperature.cpp:199:3: error: 'pid_number_of_cycles' was not declared in this scope pid_number_of_cycles = ncycles; ^ temperature.cpp:200:3: error: 'pid_tuning_finished' was not declared in this scope pid_tuning_finished = false; ^ temperature.cpp:202:3: error: 'pid_cycle' was not declared in this scope pid_cycle=0; ^ temperature.cpp:303:15: error: '_Kp' was not declared in this scope _Kp = 0.6*Ku; ^ temperature.cpp:304:15: error: '_Ki' was not declared in this scope _Ki = 2*_Kp/Tu; ^ temperature.cpp:305:15: error: '_Kd' was not declared in this scope _Kd = _Kp*Tu/8; ^ sketch\temperature.cpp: In function 'void updatePID()': temperature.cpp:403:25: error: 'PID_INTEGRAL_DRIVE_MAX' was not declared in this scope temp_iState_max_bed = PID_INTEGRAL_DRIVE_MAX / bedKi; ^ sketch\temperature.cpp: In function 'void manage_heater()': temperature.cpp:634:21: error: 'K1' was not declared in this scope #define K2 (1.0-K1) ^ sketch\temperature.cpp:635:56: note: in expansion of macro 'K2' dTerm_bed= (bedKd * (pid_input - temp_dState_bed))*K2 + (K1 * dTerm_bed); ^ sketch\temperature.cpp: In function 'void tp_init()': temperature.cpp:899:27: error: 'PID_INTEGRAL_DRIVE_MAX' was not declared in this scope temp_iState_max_bed = PID_INTEGRAL_DRIVE_MAX / bedKi; ^ sketch\temperature.cpp: In function 'void temp_runaway_stop(bool, bool)': temperature.cpp:1230:12: error: 'quickStop' was not declared in this scope quickStop(); ^ sketch\temperature.cpp: In function 'void __vector_22()': temperature.cpp:1991:32: error: 'babystep' was not declared in this scope babystep(axis,/*fwd*/true); ^ temperature.cpp:1997:33: error: 'babystep' was not declared in this scope babystep(axis,/*fwd*/false); ^ 'unscalePID_i' was not declared in this scope Questo report potrebbe essere più ricco di informazioni abilitando l'opzione "Mostra un output dettagliato durante la compilazione" in "File -> Impostazioni"
#define MAX_REDUNDANT_TEMP_SENSOR_DIFF 10
Re: ERR:MINTEMP BED February 28, 2019 06:57AM |
Re: ERR:MINTEMP BED February 28, 2019 07:04AM |
