Problems with stepper drivers January 11, 2019 02:27PM |
Re: Problems with stepper drivers January 11, 2019 07:01PM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: Problems with stepper drivers January 11, 2019 07:03PM |
Re: Problems with stepper drivers January 11, 2019 07:41PM |
Re: Problems with stepper drivers January 11, 2019 09:01PM |
Re: Problems with stepper drivers January 12, 2019 12:45PM |
Re: Problems with stepper drivers January 13, 2019 05:58AM |
Re: Problems with stepper drivers January 13, 2019 04:36PM |
Re: Problems with stepper drivers January 13, 2019 05:19PM |
/** * Minimum delay after setting the stepper DIR (in ns) * 0 : No delay (Expect at least 10µS since one Stepper ISR must transpire) * 20 : Minimum for TMC2xxx drivers * 200 : Minimum for A4988 drivers * 500 : Minimum for LV8729 drivers (guess, no info in datasheet) * 650 : Minimum for DRV8825 drivers * 1500 : Minimum for TB6600 drivers (guess, no info in datasheet) * 15000 : Minimum for TB6560 drivers (guess, no info in datasheet) * * Override the default value based on the driver type set in Configuration.h. */ //#define MINIMUM_STEPPER_DIR_DELAY 650 /** * Minimum stepper driver pulse width (in µs) * 0 : Smallest possible width the MCU can produce, compatible with TMC2xxx drivers * 1 : Minimum for A4988 stepper drivers * 1 : Minimum for LV8729 stepper drivers * 2 : Minimum for DRV8825 stepper drivers * 3 : Minimum for TB6600 stepper drivers * 30 : Minimum for TB6560 stepper drivers * * Override the default value based on the driver type set in Configuration.h. */ //#define MINIMUM_STEPPER_PULSE 2 /** * Maximum stepping rate (in Hz) the stepper driver allows * If undefined, defaults to 1MHz / (2 * MINIMUM_STEPPER_PULSE) * 500000 : Maximum for A4988 stepper driver * 400000 : Maximum for TMC2xxx stepper drivers * 250000 : Maximum for DRV8825 stepper driver * 150000 : Maximum for TB6600 stepper driver * 130000 : Maximum for LV8729 stepper driver * 15000 : Maximum for TB6560 stepper driver * * Override the default value based on the driver type set in Configuration.h. */ //#define MAXIMUM_STEPPER_RATE 250000
Re: Problems with stepper drivers February 22, 2019 09:53AM |
Re: Problems with stepper drivers February 28, 2019 05:42PM |
