Marlin 2.0 bed PID: autotuned, but won't heat up June 07, 2019 03:07PM |
#define DEFAULT_bedKp 206.42 #define DEFAULT_bedKi 19.09 #define DEFAULT_bedKd 557.90
Re: Marlin 2.0 bed PID: autotuned, but won't heat up June 09, 2019 09:48PM |
Re: Marlin 2.0 bed PID: autotuned, but won't heat up June 10, 2019 04:54AM |
Admin Registered: 11 years ago Posts: 3,096 |
salfter
I tracked down a general bed-heating problem to a power-supply issue. I've been running my A8 off an ATX power supply. I ran the printer off the 8-pin ATX12V connector (and a Raspberry Pi off the 5VSB output, but that isn't relevant here). With the stock bed, all was well, but I think the connector was overloaded when I upgraded to a 200W bed. On an attempted test print today, I saw that the bed-heater idiot light on the RAMPS was lit up, but not the corresponding indicator on the MOSFET board. A voltmeter across the MOSFET signal input showed the expected 12V, but I was only seeing about 3-4V on the MOSFET power input. Even when the MOSFET's idiot light came on, the power input only had maybe 10.2V on it. That's a sizable drop.
I swapped in an HP server power supply, with a PCIe breakout board that previously powered a mining rig. When I disconnected the old power supply, the wires going into the ATX12V connector were a bit scorched, and the connector broke apart when I tried to separate it. I now have a 6-pin PCIe cable with three pairs of 16-ga. wire feeding the MOSFET and one pair of a second cable driving the rest of the printer. Voltage drop at the MOSFET is no more than 200 mV or so.
Also, with the new power supply in place, bed PID is once again working as expected. I was about ready to blame a possible bed-power regression in Marlin for my problems, but that turns out to not have been the case.
Now I need to fab up a mount for the new power supply. (A new mount for the electronics is already printing.)
