TMC2208 on MKS Gen L V1 with 1.1.9 Marlin July 06, 2019 09:25PM |
/** * TMC2208 software UART and ENDSTOP_INTERRUPTS both use pin change interrupts (PCI) */ #if HAS_DRIVER(TMC2208) && ENABLED(ENDSTOP_INTERRUPTS_FEATURE) && !( \ defined(X_HARDWARE_SERIAL ) \ || defined(X2_HARDWARE_SERIAL) \ || defined(Y_HARDWARE_SERIAL ) \ || defined(Y2_HARDWARE_SERIAL) \ || defined(Z_HARDWARE_SERIAL ) \ || defined(Z2_HARDWARE_SERIAL) \ || defined(E0_HARDWARE_SERIAL) \ || defined(E1_HARDWARE_SERIAL) \ || defined(E2_HARDWARE_SERIAL) \ || defined(E3_HARDWARE_SERIAL) \ || defined(E4_HARDWARE_SERIAL) ) #error "select hardware UART for TMC2208 to use both TMC2208 and ENDSTOP_INTERRUPTS_FEATURE." #endif
Compiling .pioenvs\megaatmega2560\src\ubl_motion.cpp.o Marlin\stepper_indirection.cpp:293:130: error: no matching function for call to 'TMC2208Stepper::TMC2208Stepper(int, int, bool)' #define _TMC2208_DEFINE_SOFTWARE(ST) TMC2208Stepper stepper##ST(ST##_SERIAL_RX_PIN, ST##_SERIAL_TX_PIN, ST##_SERIAL_RX_PIN > -1) ^ Marlin\stepper_indirection.cpp:300:7: note: in expansion of macro '_TMC2208_DEFINE_SOFTWARE' _TMC2208_DEFINE_SOFTWARE(X); ^ In file included from Marlin\stepper_indirection.h:62:0, from Marlin\stepper_indirection.cpp:34: .piolibdeps\megaatmega2560\TMC2208Stepper\src/TMC2208Stepper.h:16:3: note: candidate: TMC2208Stepper::TMC2208Stepper(Stream*, bool) Compiling .pioenvs\megaatmega2560\src\ultralcd.cpp.o TMC2208Stepper(Stream * serial, bool has_rx=true); ^ .piolibdeps\megaatmega2560\TMC2208Stepper\src/TMC2208Stepper.h:16:3: note: candidate expects 2 arguments, 3 provided .piolibdeps\megaatmega2560\TMC2208Stepper\src/TMC2208Stepper.h:13:7: note: candidate: constexpr TMC2208Stepper::TMC2208Stepper(const TMC2208Stepper&) class TMC2208Stepper { ^ .piolibdeps\megaatmega2560\TMC2208Stepper\src/TMC2208Stepper.h:13:7: note: candidate expects 1 argument, 3 provided .piolibdeps\megaatmega2560\TMC2208Stepper\src/TMC2208Stepper.h:13:7: note: candidate: constexpr TMC2208Stepper::TMC2208Stepper(TMC2208Stepper&&) .piolibdeps\megaatmega2560\TMC2208Stepper\src/TMC2208Stepper.h:13:7: note: candidate expects 1 argument, 3 provided CMompiling .pioenvs\megaatmega2560\src\utility.cpp.o arlin\stepper_indirection.cpp: In function 'void tmc2208_serial_begin()': Marlin\stepper_indirection.cpp:379:18: error: 'class TMC2208Stepper' has no member named 'beginSerial' stepperX.beginSerial(115200);
[platformio] src_dir = Marlin build_dir = .pioenvs lib_dir = .piolib libdeps_dir = .piolibdeps default_envs = megaatmega2560
Re: TMC2208 on MKS Gen L V1 with 1.1.9 Marlin August 20, 2019 03:08PM |
