Marlin 1,9 and TMC2130
Posted by KevinRoberts
August 27, 2019 12:12AM
I have a FYSET F6 board and support said "The sensor less homing is not supported these days , it still need more work on firmware." I said on your version they said "As i know , Marlin doesn't support that well too" is this correct?
The problem is X Bangs on side and does not stop only with error... Wiring all looks correct and pins look correct.
If go to Marlin 2.0 the display will not work as FYSET as not made a release yet... Guess could try with out display...
Re: Marlin 1,9 and TMC2130
August 31, 2019 01:17AM
Goes time to give in with sensor less homing and wire switch back in.... as can not make TNC2130 work and take it FYSET support, will wait until Marlin fix it as does not work.
Edited 1 time(s). Last edit at 08/31/2019 01:20AM by KevinRoberts.
