Ender 3 MKS Gen L Bigtreetech TMC 2130 BLTouch 2.0-bugfix March 08, 2019 11:25PM |
#define STRING_CONFIG_H_AUTHOR "(Ed, Modifed bed level)" // Who made the changes. #define MOTHERBOARD BOARD_MKS_GEN_L #define TEMP_SENSOR_BED 1 #define ENDSTOPPULLUP_ZMIN_PROBE #define X_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop. #define Y_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop. #define Z_MIN_PROBE_ENDSTOP_INVERTING true // set to true to invert the logic of the probe. #define X_DRIVER_TYPE TMC2130 #define Y_DRIVER_TYPE TMC2130 #define Z_DRIVER_TYPE TMC2130 #define E0_DRIVER_TYPE TMC2130 #define DISTINCT_E_FACTORS #define DEFAULT_AXIS_STEPS_PER_UNIT { 79.9, 79.9, 403.63, 108 } #define DEFAULT_MAX_FEEDRATE { 500, 500, 5, 25 } #define DEFAULT_MAX_ACCELERATION { 500, 500, 100, 5000 } #define DEFAULT_ACCELERATION 500 // X, Y, Z and E acceleration for printing moves #define DEFAULT_RETRACT_ACCELERATION 500 // E acceleration for retracts #define DEFAULT_TRAVEL_ACCELERATION 500 // X, Y, Z acceleration for travel (non printing) moves #define DEFAULT_XJERK 7.0 #define DEFAULT_YJERK 7.0 #define BLTOUCH #define BLTOUCH_DELAY 375 // (ms) Enable and increase if needed #define X_PROBE_OFFSET_FROM_EXTRUDER -45.73 // X offset: -left +right [of the nozzle] #define Y_PROBE_OFFSET_FROM_EXTRUDER -15 // Y offset: -front +behind [the nozzle] #define Z_PROBE_OFFSET_FROM_EXTRUDER -1.39 // Z offset: -below +above [the nozzle] #define MIN_PROBE_EDGE 35 #define MULTIPLE_PROBING 3 #define Z_MIN_PROBE_REPEATABILITY_TEST #define WAIT_FOR_BED_HEATER // Wait for bed to heat back up between probes (to improve accuracy) #define INVERT_X_DIR true #define INVERT_E0_DIR true #define X_BED_SIZE 230 #define Y_BED_SIZE 230 //#define MIN_SOFTWARE_ENDSTOP_Z #define AUTO_BED_LEVELING_BILINEAR #define GRID_MAX_POINTS_X 5 #define ABL_BILINEAR_SUBDIVISION #define Z_SAFE_HOMING #define EEPROM_SETTINGS // Enable for M500 and M501 commands #define NUM_SERVOS 1 // Servo index starts with 0 for M280 command
#define E0_AUTO_FAN_PIN 7 #define X_HOME_BUMP_MM 0 #define Y_HOME_BUMP_MM 0 #define BABYSTEPPING #define BABYSTEP_MULTIPLICATOR 5 // Babysteps are very small. Increase for faster motion. #define BABYSTEP_ZPROBE_OFFSET // Combine M851 Z and Babystepping * f00 : Maximum for TMC2xxx stepper drivers #define E0_CURRENT 900 #define X_CS_PIN 59 #define Y_CS_PIN 63 #define Z_CS_PIN 40 #define E0_CS_PIN 42 //#define TMC_SW_MOSI 51 //#define TMC_SW_MISO 50 //#define TMC_SW_SCK 52 #define CHOPPER_TIMING CHOPPER_DEFAULT_24V #define MONITOR_DRIVER_STATUS #define HYBRID_THRESHOLD #define SENSORLESS_HOMING // TMC2130 only #define X_STALL_SENSITIVITY 10 #define Y_STALL_SENSITIVITY 10 #define TMC_DEBUG
Re: Ender 3 MKS Gen L Bigtreetech TMC 2130 BLTouch 2.0-bugfix September 07, 2019 08:48AM |
