When I started out I used the LCD to set Z-Offset in marlin to adjust the nozzle height.
You can also use.
M851 - XYZ Probe Offset to set the Z-Offset.
Today I use babysteps to nudge the nozzle into place while 3D Printing a skirt around the model using the LCD.
#define BABYSTEPPING
I have also added a spring loaded sensor mount to adjust the Z-Axis sensor/endstop into the correct position without using above configurations.
Edited 1 time(s). Last edit at 10/01/2019 09:43AM by Roberts_Clif.
