Can't adj z offset -skr1.3-bltouch
Posted by luckyflyer
October 21, 2019 01:15AM
I've recently installed an skr1.3 in my monoprice maker select 2.0. I know 32 bits is overkill but went with i because its cheap and the benefits of the bed leveling. Auto home works ok and the 9 point bed leveling routine appears to work ok. However when I print the nozzle is about 5mm above the bed. I navigate to the z offset setting on the lcd and advance to a lower number and push the button to enter but the z axis does not respond. I've changed the z offset in the firmware but that does not appear to have any effect either. I've gone through the finding the z offset routine on marlins website and am able to do that ok. I've used teaching tech's tutorial to set everything up and have gone over everything several times for omissions and or errors but cant find any. Attached are my config.h and config.adv.h files. Any help is appreciated. tia
open | download - Configuration.h (80.3 KB)
open | download - Configuration_adv.h (106.7 KB)
